Old 04-11-2002, 11:04 AM
Rgacke's Avatar
Rgacke Rgacke is offline
oil catch cans
I'm aware of how they work but was wondering whats on the inside of the can that makes the oil catch. baffles? filters? absoultly nothing?
"shut the door Joshua, and let death pass by..."
Old 04-11-2002, 11:41 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
um, what's an "oil catch can?"
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 04-11-2002, 02:22 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
I think there is some kind of a baffle system to prevent back flow of vapors.
An oil catch can traps oil vapor from your PCV or valve cover and prevents this oil from getting recirculated into the intake.
Greddy makes one: http://www.nipponpower.com/accessori..._catchcan.html
Old 04-11-2002, 03:14 PM
is that a name for those little foam filter thingies that v8 guys use in the PCV holes in the valve covers? (instead of tubes connecting to the intake)
Old 04-11-2002, 03:33 PM
SleeperTeg's Avatar
the foam blocks do virtually the same thing except for the fact that the catch cans give the vapors time to condense hence letting almost no oil return to the intake side, where as the blocks just act as a mechanical 'filter'.
Old 04-11-2002, 08:02 PM
I always figured the filters were to keep dirt out, rather than to keep oil in... Never paid that much attention to them though.
Old 04-12-2002, 12:39 PM
Rgacke's Avatar
thanks sleeperteg, I was hoping that someone that had one would let me know 'cause I can't see spending 100 on something that I could make but if there is baffles/ect. in there than I'd just buy one
Old 04-12-2002, 01:17 PM
SleeperTeg's Avatar
np
They basically just keep your engine running 'cleaner' by not letting all of those nasty oil carbons re-entering the intake. I dont have one, but have done a bit of research on them. Not really a performance part, but should extend the life of your engine and keep your runners and intake valves from getting any gummier than possible.
Old 04-12-2002, 11:17 PM
Rgacke's Avatar
heres another little tid-bit about them, if your turbocharged they help prevent detonation 'cause oil has a lower octane rating, that why I'm interested in making/buying one
Old 04-13-2002, 02:35 AM
SleeperTeg's Avatar
cool, i did not know that....thanks for the info. I will remember that one.
Oil catch can... when it gets dirty: Shpyder Off-Topic 3 08-10-2004 06:12 PM
What to use to make your own oil catch can? Talon69 Off-Topic 1 05-12-2004 09:08 PM
oil catch can hose size supafast Impreza/9-2x/Outback Sport 0 03-05-2004 01:21 AM
WTB oil catch can... where is a good place camshaft007 Engineering/ Technical 3 04-22-2003 06:02 AM
