Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-12-2005, 12:23 AM
issjoe issjoe is offline
1988 4Runner Head Gasket Start Problem
I just bought a 1988 4Runner 140k miles,V6 with blown drivers side head gasket. It started when I bought it alot of white smoke. Next day I cant seem to restart it. It turns over fine and starts to fire but wont keep running. Ive taken the spark plugs out and cleaned them and turned over engine to blow out water. There is no water in oil. I havn't decided whether to do head gasket myself or not yet. Looking for advice.Thanks Steve
Old 05-12-2005, 09:18 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1988 4Runner Head Gasket Start Problem
Toyota reportedly covers replacing head gaskets once on all 88-95 3.0 V6's and warrents them for 8 years or 100,000 miles,
Try these numbers: 1-800-404-7636 or 1-800-331-4331 to find out if your vehicle is eligible for repair of the head gasket. Another possibility is to try your local dealer.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-12-2005, 07:18 PM
Re: Re: 1988 4Runner Head Gasket Start Problem
Thanks. I called Toyota and its out of warranty. Im still looking for no start problem. It turns over fine. Fires and almost starts. I just put in a bottle of heat in gas sense its been sitting for over a year. Thinking about doing the head gasket myself and just taking in slowly. Steve
Old 05-12-2005, 10:49 PM
Brian R.'s Avatar
Resident Chemist
I had heard that this replacement policy covers the head gasket for one repair at any stage in the engine life with no mileage limit. Once it is repaired, then the warranty period I quoted above applies. Investigate this more thoroughly. It may save you alot of money or time. Search this forum and the web for more details. We have talked about it alot.
As far as your starting problem goes, I bet if you fix the head gasket, the starting problem will go away.
Old 05-13-2005, 11:57 PM
I'm getting nowhere with Toyota. They tell me the warranty was only one time, one year, unlimited milage. My position with Toyota is, because engine only went 40k before head gasket went again, there must have been faulty material or installation. In other words if it wasn't repaired correctly, that their fault. Of course Toyota disagrees. Thanks
Old 05-14-2005, 01:10 AM
Brian R.'s Avatar
Resident Chemist
They work hard to weed out the easily discouraged. Don't give up.
Old 05-20-2005, 04:31 PM
mmof3bys mmof3bys is offline
Not true! Mine is a 90' I had my head gasket replaced earlier this year. They go by your VIN# so I was to say the least "disappointed"!
Old 05-20-2005, 11:08 PM
Brian R.'s Avatar
Resident Chemist
What is not true?
Old 05-23-2005, 11:08 AM
I tried approaching Toyota with having my head gasket replaced and I had to give them my VIN# (1990 Model) and they said it was not covered.
What I meant was that was not "entirely" true..
Old 05-29-2005, 04:16 PM
Update
I went as high as I could get at the Toyota 1 800 #. The supervisor said on my vin# it was one year unlimited milage. They said it was a "courstesy repair". They put in new block and head gaskets. Anyway, that was their final position. I could put a complaint in writing, but it goes to the same department.
Ive hired a mechanic that is doing R&R of timing belt and head gaskets. He has got everything apart and the head gaskets look fine. I will be having the heads pressure tested on Tues. I bought a complete valve grind gasket set. The mechanic is doing labor for $400. The gasket set and timing belt and new bolts were $160 from engnbldr.com. So with head work I should be at about $750 which sees to be pretty good deal.Thanks for your help. Steve
Old 07-03-2005, 05:05 AM
SidneyCanada SidneyCanada is offline
22 Toyota headgasket & oil sludge recall sites:
http://www.brian894x4.com/V6headgasketrecall.html
http://home.off-road.com/~kemanuel/V6-HG.htm
http://www.showmesome.info/hilux/info/recall.htm
http://www.off-road.com/toyota/4runner/topqs.html
http://www.yotatech.com/~corey/4runner_faq.htm
http://www.thecomplaintstation.com/c...inalrecord=14/
http://www.babcox.com/editorial/ic/ic110028.htm
http://www.alldata.com/recall/make/Toyota_Truck.html
http://www.alldata.com/TSB/60/94601650.html
http://www.yotarepair.com/Campaigns.html (3.4L,V6,headgasket recall)
http://home.off-road.com/~bibelheime...eadgasket.html (3.4L,V6,headgasket recall)
http://home.4x4wire.com/erik/t100/3.4v6_headgasket.htm
http://www.jasperengines.com/pdf/5SFECoolantLeaksTB.pdf
http://www.lemonaidcars.com/secret_warranties.htm
http://www.nordicgroup.us/oil.htm#Toyota%20Sludge
http://www.toyota.com/about/news/pro...-consumer.html
http://www.usatoday.com/money/autos/...ota-sludge.htm
http://www.petitiononline.com/TMC2003/petition.html
http://www.nhtsa.dot.gov/TSBScans/sb621323.pdf
http://www.nhtsa.dot.gov/TSBScans/sb628694.pdf
http://groups.msn.com/ToyotaOwnersUn...gaskettsb.msnw
http://groups.msn.com/ToyotaOwnersUn...adgaskets.msnw
http://www.babcox.com/editorial/ic/ic100052.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 244 000 KM
Old 11-10-2005, 03:17 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Sidney,
STOP telling people there is a "RECALL" there was never formally a recall Toyota referenced it as a service campaign and it ended years ago and even then then it was not a SURE thing you would get the work paid for!!!!
Old 11-10-2005, 03:58 PM
Originally Posted by 4Wheel
Sidney,
The government in Canada & USA will force car manufacturers to recall a vehicle based on safety or emissions but the headgasket was a voluntary recall made by Toyota as many notices were mailed to customers and many customers were notified by phone.As well many owners would contact any Toyota dealership or even the head office and give them the VIN afterwards the owner would take their truck to any Toyota dealership and have the work done at no cost to them and given a free rental car.
Some people who already had the work done elsewhere would partially or completely get re-embursed by Toyota,I have read this many times on the 61 or so 4-Runner/pickup dedicated discussion sites.
ARE YOU FEELING HIGHLY TERRITORIAL? OR LOOSING A POWER
GRIP/TRIP?.
Here are the sites for you:
Here are 39 other 4-Runner/pickup discussion sites which have free classifieds:
http://www.wildyoats.com/vbulletin
http://www.yotatech.com/index.php
http://www.toyota-4runner.org
http://www.toyotaoffroad.com
http://mkelly.proboards22.com
http://www.t4x4pickup.com/dgroup/index.html
http://www.voy.com/83795/
http://www.4x4wire.com/toyota
http://forum.ih8mud.com
http://board.marlincrawler.com/index...0db2fa424afcf&
http://www.birfield.com/modules.php?name=Forums
http://www.pavement s u c k s.com/forums/viewforum.php?forum=14
http://www.automotiveforums.com/vbul...splay.php?f=65
http://www.automotiveforums.com/vbul...lay.php?f=1146
http://www.toyotanation.com/forum/f22
http://www.4wheelparts.com/forum/default.asp
http://www.pirate4x4.com/forum/forumdisplay.php?f=12
http://mtt.truckmoxie.com/forums
http://toyotatruckworld.tenmagazines.com/forums
http://4roc.org/forums/index.php
http://www.4x4review.com/discussions/toyota
http://members.boardhost.com/wildrice/
http://www.gator4x4.com/forum/viewforum.php?f=5
http://www.b2g5.com/boards/board.cgi?user=marktoyota
http://www.toyotaownersclub.com/forums/index.php?
http://www.suvfans.com/forums
http://www.network54.com/Hide/Forum/11128
http://www.toyota-parts.com/bb
http://www.toyotaboard.com
http://www.toyotaworld.com/bbs
http://forums.vmag.com
http://groups.google.com/groups?grou....toyota.trucks
http://www.talkaboutautos.com/group/....toyota.trucks
http://groups-beta.google.com/group/....toyota.trucks
http://news-reader.org/alt.autos.toyota.trucks/
http://www.totally-toyota.com/toyota...cks/index.html
http://www.autoforumz.com/Toyota-forum-65.html
http://autos.groups.yahoo.com/group/toyota4runners
http://autos.groups.yahoo.com/group/toyota4runner/
http://autos.groups.yahoo.com/group/the4runner4x4club/
http://autos.groups.yahoo.com/group/4-runner/
http://autos.groups.yahoo.com/group/4runner/
http://autos.groups.yahoo.com/group/wills4runnerworld/
http://lists.off-road.com/mailman/listinfo/toy4x4
http://ar.groups.yahoo.com/group/ClubDaihatsu4x4
These are 6 Canadian based 4-Runner/pickup sites which have free classifieds:
http://www.toyotaoffroad.ca/forum
http://www.toontoysforums.ca
http://www.4wheeler.ca
http://www.bogginfreaks.com
http://www.bc4x4.com
http://island4x4.com
These are 11 Toyota DIESEL 4-Runner/pickup sites which have free classifieds:
http://www.sr5.net/bbs/index.sht
http://www.toyotadiesel.com/phpBB2
http://autos.groups.yahoo.com/group/toyotadieselclub
http://pub12.ezboard.com/btoyotasurfdownunder
http://www.toyotasurf.asn.au/forum
http://groups.msn.com/toyotasurf/shoebox.msnw
http://www.yotasurf.com/forums/index.php?
http://www.yotasurf.co.uk/forums/index.php
http://www.offroadpakistan.com/forum...forum.php?id=8
http://clean4x4.com/
http://jplan.com/cgi-bin/tractor/for...ickup%20Trucks
http://www.biodieselsolutions.ca/
These are Turbo gas based 4-Runner/pickup discussion sites which have free classifieds:
http://autos.groups.yahoo.com/group/22RTE-Trucks
http://www.well.com/user/mosk/welcome.htm
http://www.turboparts.info/pages/620208/index.htm
These are 2 Trekker based discussion sites:
http://groups.yahoo.com/group/toytrekkers
http://www.toyotaoffroad.com/Article...er/Trekker.htm
Sidney® ™
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM
Old 11-11-2005, 12:06 PM
4Wheel's Avatar
AF - Advisor
First hand experience not from reading chat sites.
It was NOT even a recall. People use this label out of ignorance.
No never been on any power trips just you're misleading people and I don’t know why.
Please respect the trust people have with you and post responsibly
This is a great forum and has very little flaming or personal attacks regardless of where one is from. Respect here is gained by quality and accuracy of posts not quantity.
Thanks
