Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-10-2005, 04:59 PM
Maddhatter Maddhatter is offline
newbie needs help
just wanted to say hi. and I need help. so I took off my manifold to fix my leaking valvecovers now I can't keep the truck running and the front of my mainifold on the pass. side is getting soked in fuel I can see it are my hoses wrong been working at this for a while. looked at the haynes manuel, owners manuel, talked with the local dealer. I need some pics I have the vac lines for the egr system I need to know whare the bigger hoses go. and the one fuel hose not the line to cold start valve but the hose in back of the mainifold. any help would be much appreiciated. thanx in advance
The maddhatter
Old 05-10-2005, 08:08 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: newbie needs help
Welcome to the AF!
You won't get any help until you post your year, model, and engine.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-10-2005, 08:27 PM
dough! my badd I have a 90 4runner with a 3.0 v6
Old 05-11-2005, 09:08 AM
Brian R.'s Avatar
Resident Chemist
Talk with Northern Sun:
http://www.automotiveforums.com/vbul...d.php?t=406371
I think you can help each other.
Old 05-11-2005, 12:24 PM
whare my problem is at is in the back of the mainifold not the small vacum lines but the bigger lines to the minifold the fuel line from the fire wall. I don't remeber whare it goes. the 4 hoses from the front of the engine to the rear mainifold
Old 05-11-2005, 12:30 PM
Brian R.'s Avatar
Resident Chemist
Like I said, he can probably help you with your problem and you with his.
Old 05-11-2005, 01:28 PM
Northern Sun's Avatar
Northern Sun Northern Sun is offline
Send a message via AIM to Northern Sun Send a message via Yahoo to Northern Sun
Hello
im pretty sure we can help each other as Brian suggested, I have to pull that manifold off first in order to help u with location of those hoses underneath that manifold, let me know exactly what u are looking for and I will supply necessary pictures for u , sounds good? , I also need ur help with pulling manifold off, here’s the link to my post, ""N.S"" thanks
Vietcong 3VZ-E
