| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Hi all.. im new to this forum and at a total loss on my 98 Chevy Lumina 3.1 ... Noticed that my left signal light would stick on.. When the running lights are on or the auto lights would come on at dusk the left signal will stick on... (the right works fine).. After replacing the bulbs and also the Flasher.. still happening.... Helpppppppppppp what else is there to check and where do I look.. Any help would be appreciated
#2 | |
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: Signal Light Possesssed !
Make sure no bulbs are reversed. I'm assuming you mean the left is lit up bright and won't flash when the lights are on? Does it flash with the lights off?
You could try turning the lights on, putting the signal on, and take the bulbs out one at a time, and see if it starts working when one of them comes out. If so, you at least know more or less where the problem is. Look for any chafed wiring and maybe try putting the bulb back in and moving the wiring and socket around and see if anything happens. If nothing else, try splicing a new socket in. Sometimes they go bad and terminals get crossed up in them.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
#3 | |
Yes the left front signal seems to be on its high filament and will not flash when the lights are turned on... If you turn all the running lights and all lights off ... the signal will work fine....... |
#4 | |
Yeah, try turning that bulb around, and if that doesn't do it, replace the socket.
#5 | |
stupidity should hurt
your turn signal/multifunction switch is bad, common problem with these cars.
#6 | |
I have a similar problem with my wifes car 91 lumina. I can't find the flasher to change it. Her signals do not work at all any idea where this flasher fuse is HELP please!!!!
#7 | |
Registered Offender
![]() Join Date: Mar 2006
webm,
Welcome Aboard! While it's always advisable to search the forums for solutions to similar problems, please start a new thread. Posting in old threads may result in your problem not getting all the attention it deserves.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
