Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-06-2005, 12:43 AM
greg_cunn greg_cunn is offline
87 crown vic wagon... fuel pump & filter location
I dont know much about cars... (i guess thats obvious)... does anyone know if the fuel pump on the 87 crown vic wagon is in the gas tank or mounted on the motor... I have one that has been sitting up for a couple of years and am trying to get it started so I can sell it.... when I spray ether into the intake it runs... when the ether burns away it stops... The car was running well before i let it sit. If someone could send me a link where i can find diagrams on where the pump and filter are located i would appreciate it....I know I will replace the filter... and if the pump is on the motor and easy to get to I would be able to replace it too if needed. If anyone has any other suggestions on what I need to do to get it running...please let me know
thanks
greg
[email protected]
Old 05-06-2005, 02:26 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 87 crown vic wagon... fuel pump & filter location
The pump is in the tank and the filter is on the frame rail.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-06-2005, 08:08 PM
way2old's Avatar
TOKEN HILLBILLY
I believe it is in front of the drivers side rear wheel. I am doing this from memory, so it may be on the passenger side in front of the rear wheel. It is under the car and you need to put it on jack stands.
Old 05-06-2005, 09:34 PM
amo4387622 amo4387622 is offline
The filter is on the passenger side frame rail and the pump is in the tank. Most of the time the only reason the pump is on the engine is if the car is carb.
Old 05-06-2005, 09:54 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
do you hear the pump when you turn the key?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 05-07-2005, 12:42 PM
i think i hear the pump
I hear what i call a thump... when i turn the key on I hear a thump comming from the back of the car... i dont hear it continuously runing .... just a thump every time i turn the key on.
If I have to change the pump... does the gas tank have to be droped to get to it or is there another way???
thanks
greg
Old 05-07-2005, 06:08 PM
the sound you should hear would be more like a buzz for a couple of seconds then it will stop and to change the pump you would have to drop the tank
Old 05-10-2005, 01:22 AM
locopny locopny is offline
filter is on the passenger side frame rail just ahead of the rear tire. just like on the 88 I tore down.
as far as the pump? I assume its in the tank. I'll know tommorrow when I drain the tank and pull the unit out.
Do you need any glass for your wagon?
I have all of it except for the windshield...
