Old 05-06-2005, 12:29 AM
HemiGottaLuvIt HemiGottaLuvIt is offline
Send a message via MSN to HemiGottaLuvIt Send a message via Yahoo to HemiGottaLuvIt
Clear Coat going on 94 Camaro
Hey paint and body gurus, I've got a polo green 94 Camaro that is loosing its clear coat on the RH fender. The surface area affected is about 1/2 square foot rectangular bit just on top of the fender.
My question is this: Can I just buy a bottle of clearcoat and apply to the affected area to bring it back? Must I prepare the surface in anyway prior to hitting it with the clear?
Old 05-13-2005, 04:07 PM
bag91's Avatar
bag91 bag91 is offline
Re: Clear Coat going on 94 Camaro
Is it oxidized? If it is, it needs to be sanded down and primed then painted...
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 05-13-2005, 04:23 PM
Morley Morley is offline
Metallic green? Good luck.
You'll need ot sand and repaint the entire fender, just reclearing it will not work, it'll peel in a short time.
Old 05-13-2005, 04:42 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Anytime primer/paint/clear peels it means it is not properly bonded to the level underneath it. If you spray something on top of something that is peeling it may stick but when the clear underneath peels it will take the new clear on top with it.
Next problem is your base color is metallic, you can sand metallics at all or you start lifting the metallic flake and ruining the color.
What you need to do is sand all the old clear off, throw on a fresh coat of base and clear. so basically repaint the whole peice.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-13-2005, 06:34 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
i researched this for a year. chances are you have defective paint. eventually your entire car will begin to peel just like that fender. see this post http://www.automotiveforums.com/vbul...d.php?t=378097
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 05-13-2005, 09:04 PM
bag91's Avatar
Re: Re: Clear Coat going on 94 Camaro
LOL....trying to get him to sue...
Wasn't the defective paint for 3rd gen Camaro's...?
And by the way oxidation is normal if you don't wax, now if the paint was peeling then you could get a lawsuit.
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 05-13-2005, 09:12 PM
Re: Re: Re: Clear Coat going on 94 Camaro
Yes it was. By 94 they had given up on all of the gimmics they had tried to use to get off cheap...ie base coat that needed no primer....failed, a water based primer...failed, paint the base coat and letting it sit over a weekend instead of paying over time to get it done...bad idea. You have 24 hrs after the color is shot to shoot the clear...then you have to respray with base.
Old 05-14-2005, 10:44 AM
No metal oxidation is observed. The base paint is still present and fully intact. It's just the layer of clear that is gone. It's only in this one spot. I believe it may have had very slight stone chip in that area. I'll post a picture today
