Old 05-05-2005, 10:06 AM
WayOutCat WayOutCat is offline
please advise on cat heat problem
bought a 1998 200SX SE-R that is lowered two inches.
handles great, but the catalytic converter leaves burn marks on the grass where i sometimes have to park.
are there aftermarket catalytics that get less hot? are there other legal solutions? (aside from raising the car--that i won't do)
aside from the fact that it's illegal to just remove the cat, i'm chosing to not do that because the oxygen sensors would play merry hell with all kinds of fuel-air computational bullshit i don't understand with the cat gone.
any advice?
thanks in advance!
Old 05-05-2005, 12:24 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: please advise on cat heat problem
Its quite possible that your cat is plugged with hydrocarbons and needs to be replaced. There are aftermarket cats that flow better and will probably run a touch cooler. Depending on where you live, some of them are smog legal. Your emissions will probably increase with a high-flow cat but usually they'll stay within spec.
Make sure your heat shield is still in place, too. It may have been ripped off by a speed bump.
Dragging people kicking and screaming into the enlightenment.
Old 05-05-2005, 12:37 PM
thanks! heat shield is still there and since i live in michigan, i'm sure that *any* cat will be legal here.
any suggestions?
Old 05-05-2005, 12:48 PM
curtis73's Avatar
Dynomax and Catco make performance high-flow cats. Should be about $100 from summit.
www.summitracing.com
Old 05-05-2005, 12:49 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: please advise on cat heat problem
any suggestions?
Becareful if you live on the East side of the state though. I know anything is fine here on the west side where I live but over buy Detroit they do have emissions testing.
Old 05-05-2005, 01:37 PM
thanks a mil, Curtis!
(you have helped me out before with good advice, thanks big time; yer a swell guy!)
any further opinions by anyone on what high-flo cats are best would be welcome!
