| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
OK i read that HUGE thread on airbrushes in the FAQ but i still have some other questions.
1) I got this airbrush froma friend to use as practice before i get my own. He said it was his uncles before he got it and he doesnt know what company and what not this airbrush is. Here are somes pics: Does any1 recognize this airbrush? or maybe have some info on it. The only numbers/letters on it i already search on google and got nothing. Any info would be great. 2) I was wondering if this aircompressor would work. Pics: This is the compressor my dad just bought for household stuff i asked him i could use it he said sure. I checked the fitting for the compressor adapter for the airbrush i have and it fit. I was just wondering would this be a good compressor? what else would i need? 3) Ok what exactly does a moisture trap look like? The compressor has a thing at the bottom and the instructions say to open it up after every use to release water build up. So iam wondering what does a moisture trap look like and do i need one for this compressor? And if so, where do i attach it. Thanks a lot guys Ron
Re: Airbrush + Compressor Questions (Already Searched)
I dont see any pics?
-Mike AF Director of Media / Photographer ![]() [email protected] | AutomotiveForums.com | Flickr Gallery |
The Airbrush look to be campbell hausfeld (rebrand Badger) Not too bad for starting.
That compressor is WAYYYYYY overkill !!!
![]() CarsModeling.com. My Scale Model Cars blog. |
The airbrush is essentially a Badger 150 dual action airbrush. It's a terrific airbrush, I use mine for 90% of my spraying.
The compressor is definately more than you need, but it should do the job fine. You'll probably need a pressure regulator. Badger and Paasche probably sell them, as well as other suppliers. If that's a vinyl air hose, you'll need to replace it with a braided one.
PHOTOBUCKET SUCKS |
Don't mean to hijack your thread, but it's better than starting another one. I have a compressor that ranges from 10psi to 100psi and was wondering if that would work for a compressor. It is mainly used to inflate our car tires.
Re: Re: Airbrush + Compressor Questions (Already Searched)
Anyway, we got it right ![]() Quote:
For a modeling freak like you, I guess bigger is better, but for newcomer...
Haha...me, a modeling freak. I'll take that as a complement.
Re: Re: Re: Airbrush + Compressor Questions (Already Searched)
it was If it's 99$ then ok But that kind of COmpressor here are 249$ and over. While 2 or 3 Gal are 99$-149$ But I agree, if he already have it, then use it, But it's still not a good choice for someone that look to start airbrushing and have nothing
I believe Harbor Freight also offers a similar looking airbrush, just generic parts, for about $20. I got the Badger 350 knock-off for $5, and Badger parts with with a little work.
It may look the same and use the same parts as a Badger, but it is likely much lower quality, so be wary of that. |
WOW thanks guys for the over whelming replies!
Vric: yes you are right, at first when i saw the compressor i thought wow thats juge, thats gonna be more then i need. But i think it will work. And yes as mike said i did not pay for it . I asked my dad how much he paid, he said he got it for 150 canadian which is a good price for this kind of compressor.MPWR: The compressor already has a regulator. Its located right before the connector for the hose. So that should do the trick. And why do i need a braided hose? shouldnt this one do the job? Ok so all my q's were answered cept the moisture trap ones. So what does it look like? and do i really need one? thanks again Ron
http://www2.towerhobbies.com/cgi-bin...?&I=LXDD33&P=7
They look like that, with or without the regulator attached. I like that regulator because it's 0-60 psi, rather than 0-150+ like the one that comes with most compressors, so it's easier to adjust over a smaller range (Try and get find exactly 17 psi on a broader gauge). I would run the line from the compressor into the appropriate side of the regulator, mount the regulator where you can reach it, and then run the other line to your airbrush. A water trap is a must because when you compress air, you compress the water right out of it, and the trap will stop it from reaching your airbrush and affecting your paint job. |
This will be filled with water over time and that is why the valve needs to be opened to release the water build-up. As for your compressor I think it should have a moisture trap but I can't see it... Maybe someone can help you with this.
What is understood need not be discussed
The clear container filter is a moisture trap, but they are very crappy. They filter out larger particles, if your lucky. They are the biggest piece of junk especially for larger compressors. I'll post a pic of one of the moisture traps I use.
I was trying to explain about the moisture trap and somehow the words coming out of my brain didn't get to my fingers I am using somewhat the same type of clear container for my compressor (it's a small table top compressor). It works for me, maybe not for the larger compressor .
