Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-08-2002, 10:30 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Blow off Valve Question.
Sometimes I head Loud Blow off Valves and sometimes I hear quiet ones. What makes it loud or soft? Is it how much boost you are running or is it the kind of BOV that you have?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 04-08-2002, 11:11 AM
Grendel's Avatar
Grendel Grendel is offline
I think it depends on who makes it... but I'm sure a turbo making 10psi is going to be a bit louder than one making 5psi *shrugs*
Not really sure tho
-Grendel
Old 04-08-2002, 12:04 PM
Not really sure tho
-Grendel
Thank you. Is there anyone else that knows this question?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 04-08-2002, 03:59 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
it depends on the piston design. some have smaller pistons than others, producing less noise. others just have smallish openings, resulting in a high pitched whistle. some have horns to amplify the sound. and a few have dual drive setups, two pistons with the ability to adapt for a wide range of boost without changing springs which will whistle at low boost but have a deep "whoosh" at high boost (HKS Super SQV BOV).
Old 04-08-2002, 07:13 PM
accord_GS-T accord_GS-T is offline
Banned
depends alot on the type u buy. the greddy type s sounds much different then the hks. the sound stays pretty much the same at different boost levels, its just loader under higher boost.
Old 04-09-2002, 01:16 PM
If I have a Greddy Kit running 7PSI What BOV do you recommend to give the loud Whoosh?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 04-09-2002, 04:14 PM
drift's Avatar
use the BOV that comes with it, the Greddy Type-S i believe.
if you want louder, get the original Blitz single drive BOV or the TurboXS type-h RFL.
Old 04-09-2002, 05:33 PM
Actually the Greddy Kit does not come with a BOV that is why it is Street Legal. If it had a BOV it would not be legal in California.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 04-14-2002, 02:17 AM
super 96 accord's Avatar
super 96 accord super 96 accord is offline
Also, the same blowoff valve will make a different sound on different cars even running the same boost. Dont' ask why, it just does. We put an HKS one on a civic, and an eclipse both running 6PSI and the blowoff sounded totally different.
I think in one of my previous lives I was a mighty king, because I like people to do what I say.
Sometimes I think the world has gone completely mad. And then I think, "Aw, who cares?" And then I think, "Hey, what's for supper?"
Old 04-15-2002, 04:29 PM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
BOV's have a baffle built in. If you take it out you can make them louder. I read that in a thread either on this board or on www.3si.org a while ago.
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 04-16-2002, 12:35 AM
iLLuCiv99's Avatar
iLLuCiv99 iLLuCiv99 is offline
Send a message via AIM to iLLuCiv99
Will a BOV still work good w/ auto/turbo? Does the throttle being wide open at all times, does that affect the BOV? Thanks for the info
J+L
Old 04-16-2002, 07:17 PM
Banned
your throttle body will still close in between shifts... i have seen lots of auto eclipses running with bovs....they blow just like a stick
Old 04-18-2002, 12:53 PM
fjt fjt is offline
HMMMM I thought the GReddy kit was street legal due to the fact that it is CARB approved thus making it legal.The other Kits are not(except now for the new APEXI kit)
Old 05-09-2002, 11:08 PM
BoostinSOHC's Avatar
BoostinSOHC BoostinSOHC is offline
Send a message via AIM to BoostinSOHC
actually a BOV on an automatic car functions differently from that on a manual. The throttle stays open all the time on an automatic as long as you have the petal down. It will not blow off in between shifts but it doesnt need to. Also the turbo only has to spoon once in an automatic, unlike a manual, where it has to respool evertime you shift gears. The reason it blows off is because the car has gone from boost to vacuum (when you take the foot off the petal to shift gears). In an automatic it will only blow off when you take your foot off of the gas.
Keith
1.6 Turbo Civic
Old 05-13-2002, 09:22 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
Thats pretty close, but autos can also blow off. It depends on the gears. If you're reving at 7K rpms and have 12lbs of boost and tranny shifts, the RPMs will fall raising the boost and opening the BOV. It all depends
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
blow off valve questions....z32 TT apostrophe28 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 3 04-27-2005 10:42 PM
Blow off valve question 90TurBoboi36 Performance 1 08-30-2004 03:42 PM
Blow Off Valve question... eclipsefan98 Street Racing 11 08-16-2004 11:36 PM
blow off valve question moger21 Impreza/9-2x/Outback Sport 5 07-12-2004 09:37 PM
