Old 04-07-2002, 09:51 PM
integra@jmu integra@jmu is offline
Send a message via AIM to integra@jmu
Question any advice??
I have been advised a few different ways as far as redoing my engine in my '94 Integra goes. The only thing for sure, new tranny...five speed!
First--> buy a new type r spec engine (and tranny)
Second--> keep my bottom end and buy a type r head
Third-->rebuild my engine and get some new parts (ie: flywheel & cams)
What would you guys do? Or other suggestions?
Thanks
:smoka:
Cops love to dick ya!!
Old 04-07-2002, 10:32 PM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
It depends where you want to go.
For example
LS has long gears which makes it good if you got turbo or have lots of power. Its also gets better gas milage than any other tegra trans.
Type-R is good because it has LSD in it, a big plus. It aslo is good for Vtec engines, because it keeps you inside the Vtec powerband when shifting, which makes it faster.
Depending on your engine condition, you might consider rebuilding it. That way you get more power from wahtever mody you plan.
Depending on how much money you got, second option will be the least expensive, but not much gains from it.
When building a your bottom end (for NA) go with 10.5:1 or 11:1 compression pistons, also biring it .020 over will make sure that you block is in good shape to be further modified.
good luck
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Any Advice? GreenHornetV6 Car Audio 3 05-24-2002 04:25 PM
any advice onesojourner '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-10-2002 05:31 PM
Any advice for a newbie? igotnothin Accord/TSX/Accord Hybrid 9 02-21-2002 11:22 PM
'bout to give up on my brakes...any advice 99se Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-14-2002 09:06 AM
Just got a VR-4...any advice on what to do next??? clos1428 3000GT/Stealth 2 01-29-2002 09:09 AM
