Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Dirt Bikes
Old 04-29-2005, 01:18 PM
rootie rootie is offline
cr 250 jetting
hi, just put a pro-circuit works pipe and silencer and boyesen power reeds on my '94 cr250. now it wont idle and is sluggish on the low end. once it's running, if i hit the gas hard it stalls out which makes me think maybe i need to use a leaner pilot jet or a different needle position. the elevation i ride at is 800-2000 feet. any help is appreciated.
Old 05-04-2005, 11:05 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: cr 250 jetting
Rootie...sounds like you may need to go the opposite direction on the pilot jet. Looks more like a lean condition and you need to go richer on the PJ for your idling and low end problem. How many turns is your air/fuel mixture screw at?
Have you done a plug read and checked the color?
Timeslip 08/12/06
AF Community Guidelines
Old 05-04-2005, 10:48 PM
mustangmike351c mustangmike351c is offline
you need a bigger main jet. you getting more air through the motor with the same amount of gas. richen the idle scew up and a bigger main jet and you be good to go
