Old 04-28-2005, 09:38 AM
rsxse240 rsxse240 is offline
project-get rid of ugly wheels, the hard way
ugly wheels
do something about them....
first mark where you want the rim to mount. I use dial calipers for precision
then mount the rim to a drill (a sort of ghetto lathe) and clean the chrome off of it for glue.
then bend some plastic strip around a round object to "coil" it for easier mounting to the rim.
next, after cutting the strip to the right length, glue the plastic strip to the rim and fill in the gap with your favorite filler. I used a piece of wire to hold the new rim in place as the glue set up and cured.
I then rmoved the wire and used various implements (tools) to get the rim smooth, and formed to desired shape with a slightly tapered lip.
here is what the look like on the car before paint, with some XS Tuning tires.
and after paint without tires, still kinda wet
I forgot to get the pics of the inner rim being applied, but the process is the same. you may need a center rim for support if you are using very wide tires. you could also use one solid piece for the rim, though it will be much harder to form around the "stock" rim.
another option would be to make the lip and new low profile tires out of styrene and just have no name side walls on the tire, this way you can get as wide a tire as you like......
I hope this has been helpful/informative, I know it has been fun for me...
oh and it only took about an hour to do this entire process (depending on your glue and filler)
_Ken
Old 04-28-2005, 09:43 AM
remus_nl's Avatar
remus_nl remus_nl is offline
dang nice job keep posting
Old 04-28-2005, 07:45 PM
TheBenzon TheBenzon is offline
Re: project-get rid of ugly wheels, the hard way
very nice indeed
