Old 04-27-2005, 09:19 PM
86celica_gt 86celica_gt is offline
ENGINE PROBLEMS... knock knock ...NEED HELP!
I NEEED HELLLLLP!
I have an 86 gt and theres is a very loud knocking sound coming from the engine. It occurs at different stages of rpm's. It is undriveable at the moment as the sound is way to annoying and car feels kinda unsafe to drive.
Need some suggestions
Old 04-27-2005, 09:52 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
spun bearing
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 04-27-2005, 11:17 PM
Re: ENGINE PROBLEMS... knock knock ...NEED HELP!
This is what? How should I go about fixing it?
Old 04-28-2005, 08:19 AM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
not necessarily spun bearing, but a good chance. So it sounds like a hammer to metal knock? Theres a good chance thats the motors knock onto heavens door...
Old 04-28-2005, 10:11 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
It sounds like you have a case of rod knock.
If that is the case your engine needs to be rebuilt with some new bearings.
Old 04-28-2005, 11:40 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
If you stopped the car immediately, chances are you'll just have to replace bearings. If you scored the main saddles (very likely) it will require a complete engine teardown (every single nut and bolt) and a trip to the machine shop. Sorry to be the bearer of bad news, but a spun bearing is a pretty serious thing from a machinist standpoint.
Time to really assess what this car is worth to you. A new engine will probably cost more than the car is worth.
Dragging people kicking and screaming into the enlightenment.
Old 04-28-2005, 03:00 PM
Well that's shitty news. Anyways thanks for the replies...hope for the best
