Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-07-2002, 01:32 PM
Digitalcivic Digitalcivic is offline
Send a message via AIM to Digitalcivic
ZC problem overview
ok here is the deal. My ZC runs pretty good. Nice and strong. but:
-after idling for a little bit it starts smoking really bad. also smokes sometimes when I'm getting on it
-i'm only getting around 200 miles (max) to the full tank under normal driving conditions.
-sometimes when i'm just driving normally the car will just stop accelerating in first or second gear. (i'm not sure if its a clutch/tranny problem or some kind of fuel injector problem.)
I'm using a 89 teg ecu and have replaced the wires, plugs, rotor/cap, tps, waterpump, and timing belt at time of swap.
so, anyone think they can help me out. to get this thing running perfect.
P.S - i'v got extremely bald tires on at the moment too.
red 91 hatchback
DOHC 1.6l ZC
DCsports header
gunmetal Motegi MR7 wheels
Old 04-07-2002, 01:35 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: ZC problem overview
Did you change your oil?
Old 04-07-2002, 01:48 PM
yea, changed it when i did the swap and then again about 600 miles after first driving it.
red 91 hatchback
DOHC 1.6l ZC
DCsports header
Old 04-07-2002, 01:53 PM
mellowboy's Avatar
OK i know it can't be your clutch and tranny. Maybe it could be the fuel injectors. Did you get the rite plugs? Maybe you might wanna try to regap it ..just incase.
Old 04-08-2002, 01:15 PM
88ReX 88ReX is offline
It sounds like a fuel related problem to me. I suggest putting some carb/injector cleaner in ur tank and at least in the next few...also try some HEAT brand fuel additive(or similar) to remove water. also make sure that all vacuum hoses(if you have any) are plugged in so that unneccesary air isn't getting in. Air filter, oil, injectors would be the best to start with.....GOOD luck
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
