Old 04-07-2002, 01:43 AM
grey16 grey16 is offline
what kind of cams?
Hey i'm looking for a set of cams for a b16a what would be the best for the the buck? my future plans are to either do a 50-75 shot nos or drag 3 turbo? if i could do both i probly will. right now i'm leaning more to the turbo but what works well and gives the best power. thanks. and also what do you think of tanbe exh sound and proformance?
95' civic ex w/b16a
4 SALE
1995 toyota 4 runner
SR5 Limited, loaded
Email for info @ [email protected]
Old 04-07-2002, 12:58 PM
delsolguy's Avatar
delsolguy delsolguy is offline
Send a message via AIM to delsolguy
For your purposes, it sounds like a set of Civic Type-R or '01 spec Integra Type-R cams would work good.
Tanabe exhausts are fine, although on at least the Racing Medallion (not sure about the other models), there is a bottleneck that needs to be taken care of near the begining.
1997 del Sol VTEC
Basic Mods completed. Dreaming of a set of cams...
Old 04-07-2002, 08:01 PM
thanks for the help. what kind of price I'm i looking at and i will need to put the type R valve springs in also? thanks again
95' civic ex w/b16a
4 SALE
SR5 Limited, loaded
Old 04-07-2002, 09:14 PM
delsolguy's Avatar
Yes, Type-R springs are definitely a good idea. That way you will be able to benefit from the increase upper-rpm power of the CTR/ITR cams.
A set runs about $450-$550.
1997 del Sol VTEC
Old 04-07-2002, 09:56 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
Hey delsolguy. You were talkin about the bottleneck and it needin to be takin care of what do you mean. That is the cat-back that i am gettin and i would like to know what you mean
Old 04-08-2002, 12:10 AM
Rice-Rocketeer Rice-Rocketeer is offline
Why get good NA cams to them go FI? If a turbo is in your future forget the cams.
Lookin at my gucci, it's about that time...
Old 04-08-2002, 01:00 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
agreed
Old 04-09-2002, 06:22 AM
delsolguy's Avatar
I just suggested the cams because they were fairly mild, and wouldn't hurt his power. Actually I forgot about Skunk2, which I believe just came out with a turbo-grind cam. Not sure about that.
If I can remember correctly, at the beginning of the B-pipe on the Tanabe, there is a point where the ID of the tubing is smaller than 60mm. That's the bottleneck. A local GSR dyno'ed with and without the restriction, and gained 3 whp without the bottleneck.
1997 del Sol VTEC
Old 04-10-2002, 06:49 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
CTR and ITR cams are pretty aggressive.
Overlap with VTEC is bad enough already...
Get B17A cams...the mildest B-series VTEC cams (i'm pretty sure..the first Gen. B16A might have 'em beat)
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 04-11-2002, 03:50 PM
delsolguy's Avatar
Originally posted by delsolguy
fairly mild
Compared to Toda, JUN, etc.
1997 del Sol VTEC
What kind of paint for my front grill,do I need some kind of plastic primer 1st 2005chevimpala Impala | Impala SS 0 03-11-2007 10:50 AM
What kind of hp #'s with what mods? ricergribbs '88 - '91 Civic | CRX | Wagon | Shuttlee 17 03-11-2004 01:43 AM
What Size Wheel, What Kind? thewoahna Tires and Wheels 6 03-03-2003 02:32 PM
What Does Your Car Run In 1/4 Mile, And What Kind Of Car You Have? crxfanatic_88 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-01-2003 12:27 AM
What kind of cam gears? relientokay '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-29-2002 12:53 AM
