Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-25-2005, 01:54 PM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
New Intake Manifold Design?
Yea well about 5 months back i had my intake manifold gasket replaced at a shop and i dont think that the new design was in or if they used it. Anyway so my question is after i spent the money putting the old type of gasket back in i fear i will have the same problem. Would i be able to get GM to replace the Inatke gasket u think? I know i shouldn't hold my breath but i figured i'd ask.
Old 04-25-2005, 07:19 PM
MCO_Death MCO_Death is offline
Send a message via AIM to MCO_Death Send a message via MSN to MCO_Death Send a message via Yahoo to MCO_Death
Re: New Intake Manifold Design?
If GM did the service to replace the part in the first place, you might be able to achieve a repair if its a repeating problem, if it wasn't a GM shop, your SOL for sure.
Old 04-26-2005, 01:25 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
If the dealership did the work, chances are they used the newer design gaskets as they have been out since 7/02. If an independant shop did the work, and they bought the parts at the dealership, see if they list the gasket part # on your invoice. the number for the new gaskets is 89017279. The mechanic was also supposed to replace the intake manifold bolts with new ones from GM. They have a pre-applied threadlocker on the bolts. Their part #'s are 11588915 for the shorter bolts, and 11588914 for the longer bolts.I would go back and ask them if you are unsure.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 04-26-2005, 03:13 PM
Pat_OD's Avatar
i know he put new bolts in but i'll have to check on the gasket part number, and no it wasnt a dealership.
Old 04-28-2005, 09:33 AM
tom3 tom3 is offline
Have a couple guys at work with GM cars that have had the gaskets or manifolds replaced, no help from GM in any of these. Think all new GM cars should have a spare set of gaskets in the trunk with a coupon for free install. Maybe Toyota could redesign the intake sealing for them? This is ridiculous.
