Old 04-24-2005, 08:01 AM
Laaars Laaars is offline
Paint removal
Hi
I screwed up when I first painted my 206 WRC. I used grey primer, and then white Tamiya paint.
Then, after a LONG time I finally sanded down the areas to paint it again, but the white paint is baaad, doesn't cover well, have to spray a lot to cover it ++
Then, I tought about NOT painting the bottom line of the car, since the body is molded in white plastic, but just cover it with clear coat.
So, I have the body with a bad white line on the bottom, and the tought of sanding it down again is killing me.
Isn't there an easy way to remove the paint? Like a paint remove-chemical-thing? That wouldn't damage the plastic?
Old 04-24-2005, 08:45 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Go to your local grocery store, get a bottle of 99% isopropyl alcohol, put it in a covered container large enough for the body, and let it soak for a couple of days. Scrub it with an old toothbrush, if necissary. It will safely remove Tamiya laquers and acrylics (and the primer, too), and won't hurt the plastic.
PHOTOBUCKET SUCKS
Old 04-24-2005, 08:55 AM
Re: Paint removal
Thanks a lot! You saved my day
Old 05-01-2005, 01:46 PM
Re: Paint removal
Haven't got 99% alcohol yet, but, can i use Thinner instead? Or will it destroy the plastic?
Old 05-01-2005, 03:56 PM
campenr.1's Avatar
campenr.1 campenr.1 is offline
Re: Paint removal
Use break fluid instead. Donīt have to let it soak days - just overnight works perfectly with tamiya paint.
Current and past projects:
Old 05-01-2005, 04:12 PM
MkIIboi's Avatar
MkIIboi MkIIboi is offline
Re: Paint removal
Yah im using Dot3 brake fluid right now. Its working great. If i were you i would go with the brake fluid. Just let it soak in a bowl or something overnight.
Not my car, but i wish it was...
Old 05-01-2005, 06:22 PM
MPWR's Avatar
No, don't use thinner, it will attack the plastic. Brake fluid does work but why use a more toxic substance if you don't have to? Isopropyl works just as well, and you don't have to find a safe way to dispose of it afterwards.
PHOTOBUCKET SUCKS
