Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-06-2002, 03:51 PM
velocitySiR's Avatar
velocitySiR velocitySiR is offline
Send a message via AIM to velocitySiR
before i set this thing on fire anybody got any ideas.
ok the problem is it was sputtering and being a pile pretty much, then we found out the first cylnder wasn't firing, i dropped a new set of plugs in, NOPE, new cap and rotor, NOPE, and today i just got 4 new wires NOPE...... the only thing left could be the fuel... and i would i check to see if that injector is failing....please help, or that yellow thing is gonna be a toasty black.
formerly "riceboi" back at ph
1990 Crx Si ..b16a1 ...i/h/e ...PYR Racing head..ctr pistons .. ...flywheel ...stage 2 clutch ...3.5 drop on Ground Controls ...Koni adj's all around ... ...mugen kit ...sloppy yellow paint job ...apex'i vafc ...gsr brakes ...gsr seats ...autometer a/f gauge ...and more crap that nobody cares about
Old 04-06-2002, 07:25 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
An Injector could be stuffed or one of the seals around the injector could be leaking. Fuel pump might also be a possible issue. Checked your fuel filter recently (I know it sounds obvious but I'm trying to cover all bases). Is it happening under load or at idle?
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 04-06-2002, 08:01 PM
no all cylnders are running fine besides #1... i guess it coulda got clogged maybe? i dunno or maybe there's a bad connection to that injector.... drawin straws man.
Old 04-06-2002, 08:04 PM
oh yah it has a rougher idle now and acceleration is just crap, i mean go figure on 3 cylnders.
Old 04-06-2002, 09:20 PM
Setanta's Avatar
Hmmm... if the injector seal is leaking then it's drawing air in - spray some WD40 around it to see if that briefly changes the idle.
The injector can get clogged and can also fail to pulse leading to rough idle. Prolly worth getting a leak-down test done on the head to see if there's a burnt or damaged valve that isn't sealing properly. Have you done a compression test recently?
'99 PY DC2R
'85 BBS BMW E30
Old 04-07-2002, 03:32 PM
damn, it's sounding pretty bright..... we did a compression test and it read 185 on that cyl that isn't firing... so that was good, then we checked the voltage going to the injector and it was getting power and you can hear the solenoid clicking when the engine is running...... so next we popped off the fuel rail and that injector for that cyl was bone dry on the nozzle side and there was fuel going to it on the rail side of it... so i'm hoping it may just be clogged.. i pray. hahah..... by the way what injectors would work in that????
and moppie i have a shitty memory but i think my engine number was like 1027412, i think, it's prolly off.
Old 04-07-2002, 11:44 PM
Setanta's Avatar
Best guess is to get an injector off a B16A 1G 'teg or 4G civic. Just to make sure that it flows as well as the other 3, not better or worse.
But you knew that anyway
'99 PY DC2R
'85 BBS BMW E30
Old 04-08-2002, 01:28 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Finnaly!
Do what Setanta, said, sounds like you might be onto something there.
Ok, your engine is from a proboly 91 XSi Integra. The numbers pretty high, certianly a lot higher than mine. (but there more Tegs made)
Could also be from an RSi, check the g/box code, its the the one that come with the engine, then a S1 is from the XSi and a YS1 is from the RSi. (differnt ratios)
Now, the Dizzy should be the same as all the others, are you sure you didnt get them confused at the shop? and you are infact useing a USDM B16a one?
And please dont burn it!!!
Old 04-08-2002, 12:32 PM
yah i found a set for 40 used.... bitchin. this better be the last part i buy for this damn prob.
Old 04-13-2002, 10:51 AM
dreemkill dreemkill is offline
Send a message via ICQ to dreemkill Send a message via AIM to dreemkill Send a message via Yahoo to dreemkill
Re: before i set this thing on fire anybody got any ideas.
upstate ny? where? im in binghamton...........
Originally posted by fakirone
.... Nos this, nos that, my 10 second nossy nos will nos your nos.
Originally posted by Prelussion
And then both of you guys w/ you sewing maching powered cars get passed by a moped w/ a 5hp Engine and he goes on to put 5 car lengths on you. Racing an EX vs a DX is like a 10 speed bike vs a golden retriever.
AF Upstate Crew -- Member #1
Current Audio: none. car dead.
transmission leak (correction COOLANT LEAK) photo...anyone got any idea? JoshBarber Blazer 21 04-06-2006 02:35 PM
Does anybody got any ideas on this? RiskBeMe Metro 4 11-22-2004 03:21 PM
got any ideas? JacobG Lumina 0 05-23-2004 02:23 PM
used HEADERS anybody got any??? comp Camaro Discussions 0 01-19-2004 04:44 PM
anybody got any pics of some Ro_ja Formula 5's Wes Moran '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 07-06-2003 10:34 AM
