Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-23-2005, 02:36 PM
miekedmr miekedmr is offline
Question How do I remove/install the sway bar??
I have a 94 2wd pickup and my old sway bar got mangled and broke one of the endlinks. It was useless so I just cut it in half to get it out. I got a sway bar from the junk yard by cutting through one of the bars that run under it (torsion bars?) and now I'm trying to wiggle that one under my truck. I CANNOT figure out how to fit it through there with the torsion bars in place. I even removed the brackets going from the engine block to the tranny to get more room inbetween. Someone please give me some guidance.
Old 06-16-2005, 10:17 PM
zachary zachary is offline
Re: How do I remove/install the sway bar??
There is really no way to get around the torsion bars, youll have to take um off, put the sway bar on, then put the torsion bars back on. Takin the torsion bars off is kinda tuff,they are spring loaded, a manual will give you instructions on takin them off.
Old 06-16-2005, 10:39 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Removal of torsion bar:
http://personal.utulsa.edu/~nathan-b.../9torsionb.pdf
Stabilizer bar:
http://personal.utulsa.edu/~nathan-b...13stabiliz.pdf
According to the link, you only have to remove one torsion bar
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-17-2005, 08:06 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
Don't forget to get an alignment after removing a torsion bar.
WAR UTAH!!
