Old 04-23-2005, 10:02 AM
Sean May Sean May is offline
Question Can't Fill Up
Hey Guys,
I need your help.
I can't fill up my 2005 F-350.
It took me 20 minutes to put 4 gallon in her today.
No matter how I hold the gas nozzle, it just keeps shutting
off.
Any suggestion on what may be blocking the gas/nozzle
from going in.
thaks alot.
sean
Old 04-23-2005, 08:30 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: Can't Fill Up
thats strange... ive never heard of that happening. Did you try a differant pump? If not then it may have just been that gas pump.. but if so then i would reccomend taking it to the dealer.. its under warrenty if its an 05..
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 04-24-2005, 05:43 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Can't Fill Up
Somewhere in the fuel system there is a vent that is plugged. Either the vent tube or the pressure sensor. As stated above, it is an 05, take back to Dealer.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-16-2005, 10:24 PM
jcougar88 jcougar88 is offline
cant fill up
there is a vent tube hose inside your filler neck hose. You need to disconnect the vent tube from the filler neck, and fish this vent tube out, and reconnect it to the filler neck before you reconnect the filler tube. If it is not in the hose, it fell into the tank. You would then have to fish it out of your gas tank. Once you do this, it will be normal again. Hope this helps. This is from past experience with the exact same problem. Took about 30 minutes to do. Good luck.
