Old 04-12-2005, 05:35 PM
Bain Bain is offline
pressing pistons to rods
I'm guessing no but before I learn the hard way I'm gonna ask. When pressing the pistons on to their rods is that any need to lubricate first? I would think no because it would stick better that way but once again I would hate to get them on and find out otherwise. Thanks
Old 04-12-2005, 08:49 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: pressing pistons to rods
Warm the pistons in your wife's or g/f's oven to about 150 deg. or so. (Tell her its a new and exotic style of cookware.) Throw the piston pins in the freezer for a while.
The thermal difference between the two will really help installation.
Old 04-12-2005, 09:48 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Agreed. When a shop does it, they heat the small end of the rod pretty hot. I don't know how hot, but the pin slips right in like a zero fit.
Don't physically use a press to put them in, you'll damage the whole works
Dragging people kicking and screaming into the enlightenment.
Old 04-13-2005, 12:41 AM
Your kidding so I heat it up to 150 then put it in the freezer till its cool enough to touch and just slide it in? That's unreal I'm glad I asked first because that is something I would never have thought of.
Old 04-13-2005, 03:11 AM
curtis73's Avatar
Yeap. Press-in pins refers more to the clearances involved more than the method used to install them. If you install them with a shop press you'll most likely cause stress fractures in the rod and failure will happen soon after. The secret is not to stretch the rod metal by pressing it in, but to let the metal relax around the pin and heat is what most commonly does the trick.
So, you heat the rod to 150 and put the pins in the freezer. The pins contract and the rods expand. Assemble them and let them get to room temperature and they'll be press-fit without the pressing.
Old 04-14-2005, 01:30 PM
Ok what do you do when you've heated up the rods and frozen the pins and you still can't get them put together? I heated them to 150 but that didn't work so I kicked it up to 200 and that still didn't work. Any other ideas or tricks?
Old 04-14-2005, 02:44 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
you could take a blow torch to heat up the end but not too hot i'm shure something around 400 degrees would work you just want to avoid messing up the grain structure in the metal making it more prone to fatigue.
I disregard my perceived image in the persuit of knowledge.
Old 04-14-2005, 03:23 PM
curtis73's Avatar
This one is out of my league since I'm not a metallurgist, but I'd bet a machine shop would let you know a good temp. There are different ways to tell by the color of the metal. Like, "cherry red" indicates a certain temp range and "white-orange" is where it turns into a puddle of goo.
I know when I get my rods back (I usually let the machine shop do that) the small ends are all discolored from the application of heat.
Old 04-14-2005, 03:34 PM
I'll try a blow torch. I can't stand to let anyone else do something on my cars that there might be even a small chance that I could do it my self. So I really don't want to have to do that here.
Old 04-14-2005, 04:00 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
wait on the blow torch. I would use a pot of heated motor oil to heat the rods up. I do it alot a work with press fit roller bearings, and they slide right on. Do not get the oil over 450 or 500 degrees though or it will remove some qualities of the metal if you get them to hot. This is also nice because the oil provides some lube.
Old 04-14-2005, 05:27 PM
Cool, alright I'll try that first them thanks
Old 04-15-2005, 06:30 PM
SaabJohan SaabJohan is offline
My tip is to used liquid nitrogen to cool the "inner parts". Unlike heating cooling won't damage the parts, unless you drop them or something like that.
Old 04-17-2005, 12:46 PM
public's Avatar
public public is offline
Turn your freezer thermostat down. Liquid nitrogen is just a little hard to find. And they usually won't sell you a thermos full.
Yes, I am retarded.
Old 04-17-2005, 01:38 PM
Usually you can rent a thermos, and buy the liquid nitrogen.
Dry ice can also be used, but one can't reach as low temperatures with that.
http://www.linde-gas.com/Internation..._shrinkfitting
Old 04-17-2005, 08:20 PM
Re: Re: pressing pistons to rods
Thanks for the link it sounds like shrinking the pins are more important than expanding the rods. Thats good cause I tried heating it up in oil today and I just couldn't get it hot enough so it didn't work either. I'll try dry ice on the pins and maybe throw the rods back into the oven at 200 or 300 tomorrow then and let everyone know how that turns out.
