Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 04-09-2005, 03:57 PM
castillorio castillorio is offline
amsoil
what amsoil filter is for a 96 v4 2.4 ext. cab taco?
Old 04-09-2005, 08:33 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: amsoil
From the AMSOIL website:
http://www.amsoil.com/scripts/runisa...msoiloaf:index
1996 TOYOTA TACOMA 2.4L 4-cyl VIN Code D 2RZ-FE
FILTERS
Oil Filter......SDF57
Oil Vapor Filter......N/R
Air Filter......TS117
Fuel Filter......GF242
Fuel Vapor Filter......N/R
Trans......TF78
BOSCH SPARK PLUGS
REGULAR CAB
Wire......B09391
Plug......B4418
All submodels
Wire......B09391
Plug......B4418
BOSCH WIPER BLADES
Driver side......B40916
Passenger side......B40916
Rear window......B40913
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
Four-wheel drive
8 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Two-wheel drive
0 Fittings, 0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL-7500 Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 0°F......10W-30
Below 100°F......5W-30
Manual Transmission,.....GL-5
All temps......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,.....GL-4
Gear Oil, API Service GL-4 - Not Available Through Amsoil
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid
Differential, W/o Adrd.....GL-5
Below -18°C......80W, 80W-90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
Differential, Front W/ Adrd.....GL-5
75W-90
Severe Gear 75W-90
Transfer Case,.....GL-4
75W-90
Severe Gear 75W-90
Transfer Case,.....GL-5
75W-90
Severe Gear 75W-90
Fluids
Power Steering Fluid.....AF3
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3 - Not Available Through Amsoil
Clutch Fluid.....HB
CAPACITIES
Engine, 2WDwith filter..........5.4 quarts[1]
Engine, 4WDwith filter..........5.7 quarts[1]
Cooling System, Initial Fill..........8.5 quarts
Automatic Transmission, 2WD Initial Fill..........2.5 quarts[2]
Automatic Transmission, Total Fill
A340E..........7.6 quarts
A43D..........6.9 quarts
A340F..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, with Cs (all) Rear..........6.3 pints
Differential, with adrd Front..........2.5 pints
Differential, witho adrd Front..........2.3 pints
Differential, 4WD extra long Rear..........4.4 pints
Differential, Rear..........3.0 pints
Differential, All with LSD Rear..........6.3 pints
1. Capacity shown includes filter. after refill check oil level
2. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....27 ft-lbs
Transfer case
Fill Plug.....27 ft-lbs
Manual Transmission
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-10-2005, 12:24 AM
thanks
