Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-06-2005, 09:08 PM
nickydontcutem nickydontcutem is offline
valve cover gasket
Yo what's up? Recently I purchased a 96 gst 5spd and when I would go WOT the car would stutter. So I looked around on the forum and figured I would change the plugs and wires. So I picked up some accel wires and bosch platinum plugs. While I was changing out the old spark plugs I found one of them to have oil on it around the threading portion of it and a little puddle of oil by the top of the wires. So I put the new plugs and wires on and it seemed to have solved my problem. But lately it's starting to stutter again and I found another puddle of oil by the wires. So I'm pretty sure that the oil is fouling up one of the plugs causing it to stutter. I've been researching on here and I wanted to know if you guys think I need to replace the valve cover gasket or is it something else.
Everything else looks good, coolant, no cracks in the valve cover. I already ordered the valve cover gasket, but I just wanted to see if I was right. Any help would be appreciated. My name is Mike.
Old 04-06-2005, 09:18 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: valve cover gasket
Just a recommendation.... try the NGK BPR7ES plugs and gap them at about .027-.028 you will be happy....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-06-2005, 09:23 PM
Re: Re: valve cover gasket
Ok but I want to know about the oil problem and valve cover gasket. Thanks for the info.
Old 04-06-2005, 09:28 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Its possible it could also be the oil cap too. But you'll know when you get your new valve cover gasket on. That is if your cover really isnt cracked...
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 04-07-2005, 10:53 PM
Thumbs up
I changed the valve cover gasket and while I was changing it I saw how the old one was brittle and falling apart. And I also picked up a new oil cap also. Thanks guys.
Old 04-07-2005, 11:49 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
which plugs aren't very good to run on a turbo car? i thought i was the platinums but i could be wrong.
95 Talon TSI AWD
97 Eclipse GST
Old 04-08-2005, 09:09 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
no, your right.
DSM geek
Old 05-08-2006, 12:58 PM
sarg74 sarg74 is offline
[Change your oil filler cap, you have a bad seal there
Old 05-08-2006, 02:57 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Are you retarded? Not only did he already do that, but this thread is over a year old.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-08-2006, 03:07 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Please do not resurrect old threads. It's in the user guidelines, did you read them when you joined? If not take a look, there's a link to them in the bottom of my signature.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Closed Thread
