Old 04-05-2005, 11:04 PM
saboe saboe is offline
94 Accord Clutch Problem
I have had a leaking master cylinder in my 94 Accord EX for a while but have not done anything about it. About once a month I would top up the fluid and it would run fine. I was out of town for a few days and returned to find that the clutch was to the floor and the reservoir empty. Filling it did not solve the problem. I replaced the master cylinder and believed that I bled the line correctly but the clutch is still to the floor and it won't let me put it into gear. Do I have a bad clutch or did I not bleed the line sufficiently? Please help! Thanks.
Old 04-06-2005, 07:57 PM
mpumas mpumas is offline
Re: 94 Accord Clutch Problem
I think there are two cylinders, one for the brake callled the master cylinder and one for the clutch. The clutch cylinder pressurizes a slave cylinder which actutates the clutch. The fluid is going somewhere and you should be able to see it under the car. Fill the cylinder, pump and look for leaks. See the below post
http://www.automotiveforums.com/vbul...d.php?t=388582
