Old 03-31-2005, 02:38 PM
87Jimmy 87Jimmy is offline
Post 88 5.0L AOD quick shifting
The tranny shifts (without slipping) but it shifts very early(quickly) and then dogs (lack of RPM).
If I select 1st and put my foot in it, it will run up(RPM's) to whenever I select D, and then shift to 2nd, 3rd like my foot is not on the pedal at all.
OD shifts at 45mph no matter where my foot is.
I was reading other posts and the MAF was suggested as well as the TPS.
Does this sound correct as in the MAF or does anyone have any other suggestions on where to look.
Old 03-31-2005, 02:54 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: 88 5.0L AOD quick shifting
an 88 mustang 5.0 uses a AOD transmission, which is hydraulically controlled. the shift points and firmness have nothing to do with the MAF sensor or the TPS, or any other electronic device. they are controlled by a cable attatched to the throttle linkage. if this cable has fallen out of adjustment, the shifting will be off by a lot... eventually this condition will destroy the transmission.
your problem is either fluid sealing inside the trans or misadjustment of the TV (throttle valve) cable. I would take the car to a reliable transmission shop and have it thoroughly diagnosed. it's too complex to figure the problem out just by describing the drivability issues, the pressures need to be measured etc. should't cost that much for a good diagnosis.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 03-31-2005, 05:33 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I'm not sure if he has a problem or just describing the normal doggy stock AOD.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-31-2005, 10:09 PM
i'm so glad i fried mine... gave me an excuse to get my butt in gear and switch to manual.
-Andy
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
Could it be that the tranny linkage isnt even hooked up so it just shifts whenever it feels like?
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 03-31-2005, 10:56 PM
GTStang's Avatar
Stang Guy
Re: Re: 88 5.0L AOD quick shifting
No, if the TV cable isn't hooked up you'll fry ya AOD in minutes. His tranny sound like the only problem it has is it's stock.
Old 03-31-2005, 11:28 PM
tturnpaw's Avatar
Re: Re: Re: 88 5.0L AOD quick shifting
Glad i dont got one, and glad i will now replace it if i get one!
LS WHAT?
Old 04-03-2005, 07:21 PM
Thanks for the input guys, I already found info about the cable an dhow to adjust. It's actually a friends car I looked at and test drove, I have a 86LTD with the AOD and mine shifts correctly. So I'll check the cable on his car (even though I prefer stick also). My weekend cruiser is a 68 Mustang GT/CS restomod in progress.
