Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-28-2005, 07:32 PM
Chris101 Chris101 is offline
Timing Belt
Well, I'm guessing the noise I was hearing had a relationship to the timing belt, because it snapped when my dad was on his way home from work. Can someone give me some light, and tell me this engine is not a valve bender? Either way, it's going to need to be replaced, obviously. How much of a pain in the ass is it to replace the belt on this car? Are their some instructions someone could possibly give me? Refer to this thread for some background.
Old 03-28-2005, 08:47 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Timing Belt
im assuming you have a zetec?
If so yes its a non-interference motor. do you have a 95-97 or a 98-00?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-28-2005, 09:18 PM
Hmm, I'm not really sure. It's sitting out in the pouring rain right now, and I don't feel like checking it now. All I know is it's a '99 2.0l DOHC. I can let you know tomorrow though exactly what it is if the info I gave you isn't sufficiant.
Old 03-29-2005, 06:51 AM
pre98zetec's Avatar
Re: Timing Belt
that's enough info
Here's a how-to on a post 98 Contour to change the timing belt:
http://www.contour.org/ubbthreads/sh...t=1&PHPSESSID=
It doesn't look very hard, Just time comsuming.
While you're down there you should probably change your water pump also.
-Josh-
Old 03-29-2005, 12:46 PM
JimR's Avatar
JimR JimR is offline
Re: Timing Belt
i replaced mine not too long ago its not hard so to say but takes a wile.
if you dont have pashents then i would take it to a shop.
Old 03-29-2005, 08:47 PM
Re: Re: Timing Belt
Originally Posted by sk8ter_in_ny
that's enough info
Wow, that's exactly what I was looking for. Thanks. I got the top timing cover off, and that belt got chewed up pretty good. Do I have to worry about that rubber getting anywhere it wasn't suppose to? Was this just simply the belt that was giving way, or is there a pulley or tensioner that I'm going to have to look into replacing in there?
Old 03-29-2005, 08:52 PM
pre98zetec's Avatar
Re: Timing Belt
You might have to replace the timing belt idler pulley, I know on mine it causes the timing belt to "slap" I don't know if thats your case. I would inspect them to make sure, but if they roll without any play then they sould be fine.
JimR- Replacing a timing belt on a pre 98 is different then replacing a timing belt on a post 98.
-Josh-
Old 04-06-2005, 04:35 PM
How exactly can I tell if the cams are in the position they're suppose to be in? I've called and looked all over for the service tools reccomended in the how- to that was posted, but the numbers don't match anything that the Ford dealerships I've called. Is the picture that is on that how-to aligned the way it should be?
EDIT: One more thing, how the hell do I get the idler off? The bolt is on there so tight. I was able to get it to move maybe .10mm, and I can move it back and forth as so, but it will not unscrew any further than that.
