Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-22-2005, 08:21 PM
Chris101 Chris101 is offline
Grinding Noise
My father's '99 Contour SE started making a grinding noise, it's the best I can describe it anyway. I poked around the engine a little bit, and I think I've found that the noise is coming from the crankshaft pulley. My question is, are their bearings in there that have dried out or something? Or is there something else I need to look in to? It's a 4 cylinder 2.0 btw. If anymore info is needed, let me know.
I forgot to mention it's got around 99k miles on it.
Old 03-23-2005, 03:33 PM
No one has an idea?
Old 03-23-2005, 07:29 PM
JoeyBoy JoeyBoy is offline
Re: Grinding Noise
Take the belt off and see if the pulley is lose or if it has any play in it.
Old 03-24-2005, 11:00 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
could be the pilot bearing.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-25-2005, 02:57 PM
Either way, would I be able to take care of this problem by just taking the passenger side tire off? Do I just need to take off that one nut on the pulley to get at the pilot bearing?
Old 03-25-2005, 03:04 PM
Re: Grinding Noise
yes
Old 03-26-2005, 05:25 PM
Is there any way, besides jamming something in the flywheel, to keep the engine from turning when I'm loosening or tightening the nut? It's an automatic by the way.
Old 03-28-2005, 12:36 AM
Re: Grinding Noise
You can try to put a pipe wrench on the pulley
