Old 03-26-2005, 09:30 PM
crazzyc911 crazzyc911 is offline
Someone Help Please?
Hello,i Have A 87 Ford Thunderbird With 3.8l V6 Efi.my Problem Is When It Starts It Runs Sluggish,when You Put It In Gear It Cuts Off.someone Please Help I Would Greatly Apprecate It.
Old 03-27-2005, 01:52 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Someone Help Please?
I would check the CTS (coolant temp sensor) first. If its not right it might not be supplying enough extra fuel when its cold. Does it run fine after its warmed up?
Dragging people kicking and screaming into the enlightenment.
Old 03-27-2005, 09:21 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Also over time, the Idle Air Control can become plugged up from carbon from the crankcase vent.
It's easy to clean the IAC and the throttle body, with a spray can of carb cleaner and an old toothbrush.
Old 03-27-2005, 10:21 AM
Adamsindrey Adamsindrey is offline
Send a message via MSN to Adamsindrey
leave it run for a few minutes (if it has manual choke leave it out) and then try puttin it in gear. My car was running sluggish for the first 5 or so minutes and wouldnt idle with the choke in so i reset the carb settings and all is fine
Old 03-27-2005, 06:18 PM
MagicRat's Avatar
Re: Re: Someone Help Please?
I would agree for carbureted cars, but crazyc says its EFI (no carb) .
Old 03-28-2005, 04:17 AM
ahhhh. my bad!
Old 03-31-2005, 11:12 AM
hello everyone,took t-bird to shop and they have replaced every sensor on the top,sides,front,and back of motor.they put it back on computer and it still showed sensors were bad.I think the computer in the car has gone on the blits.if anyone has any idea what it could be i would greatly apprecate it.
