Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-23-2005, 11:23 PM
sephman2001 sephman2001 is offline
Question If you know how to fix this you are god...
I have a 98 Ford Ranger. Its a 4 cylinder and its 2 wheel drive.
Now to the problem. I have replaced the high pressure power steering hose twice now. About 2 days after driving the truck the power steering wouldn't work anymore. When I removed the hose I found that the hose was cracked (this happened to both of the hoses I bought). This is where the problem is I don't know why the hose keeps cracking.
My father told me that it was probably a bad motor mount and that when the truck is started and the engine shakes that it is pulling on the hose and breaking it. However that idea was dismissed becasue thier is enough slack in the hose so that it isn't being pulled at all.
I appreciate all replys, Thank you
Old 03-25-2005, 06:08 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: If you know how to fix this you are god...
Could you post or send picture of how hose is installed on truck?
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-26-2005, 10:34 AM
rodeo02 rodeo02 is offline
Were these both brand-new PS hoses? I've installed 'good' used ones that leaked worse than the one I pulled off! You could have a pump issue where pressure is not being bled off as it should. Stuck pressure relief/ bypass, etc. Or maybe a rack issue. IIRC- the 1998 has rack and pinion steering as opposed to recirculating ball.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-28-2005, 06:40 PM
90stanzaownr 90stanzaownr is offline
Send a message via Yahoo to 90stanzaownr
there are different ways of fixing the problem if ur using the same brand of power steering hose switch it OR go to a hydraulics shop and have them make you a hose by matching it up with your hose you have now
