Old 03-20-2005, 07:00 PM
brian074 brian074 is offline
Unhappy '99 Taurus wagon right front turn signal doesn't work......
I've replaced both the front bulb and the side marker light bulb and I can't get the front right turn signal to work, do I have a bad wiring harness or is there some other trick I'm missing? The right rear works other than the fact it blinks twice as fast as normal, I assume that's the indicator letting you know you have a signal out.
Thanks
Brian
Old 03-20-2005, 07:25 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Have you checked for current at the bulb socket? Use a test light and see if it flashes. If there is no flash, suspect the multifunction/turn signal switch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-24-2005, 11:36 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: '99 Taurus wagon right front turn signal doesn't work......
These are good suggestions. From the schematic, it appears the multifunction switch has separate wires for the front turn signals and rears.
You may also want to try the Hazard lights. If they work fine, you know the wiring is fine to the bulbs and the bulbs are okay. The problem then is likely the multifunction switch.
What about parking lights? Do they work in the front? The bulbs use the same ground for parking and turn signals. If you have a bad ground for the fronts, it could cause your problem (turn signals and parking lights would not work or not be at full intensity). The test light would show you this as well. If the test light works with the ground lead grounded to a good ground, move the ground lead to the ground for the turn signal bulb at the socket. If the test light no longer flashes, you have a grounding issue.
Good luck!
-Rod
Old 05-04-2005, 07:35 PM
yardfixxer yardfixxer is offline
Thanks
Brian
How do you get to that front bulb????
