Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 03-16-2005, 08:27 AM
saso19 saso19 is offline
Question F4i Question ?????????
Need help on this question, I got a 2003 Honda F4I & it’s missing the whole front.
Has no front end at all. Last night I put the Bike in first gear with out a clutch and not on.
Is this supposed to happen??????
Contact : [email protected]
Old 03-16-2005, 09:06 AM
NaKeDZX NaKeDZX is offline
Re: F4i Question ?????????
Not sure what your question is....Is it supposed to go into first gear without pulling in the clutch? Yes, that's normal.
Old 03-16-2005, 11:52 AM
Re: Re: F4i Question ?????????
Thanks!
It seems like your Wright.
Well my bike is missing the clutch and I just happen to put it in first Gear with out a Clutch and with the kick stand up and the motor not running, is that possible?
I think you sort of answered my question.
Old 03-16-2005, 12:14 PM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
When you say the bike is missing the "whole Front" you might want to clarify as to what exact parts don't you have .... The bike will go into first gear without a clutch but from my experiences it will jump on you or stall out. Make sure your shifting with the kickstand up, the bike has a safety switch that will kill the motor if your shift when your stand is down.
-Jimmy
~99' Silverado z71 LS 5.3~
Alpine CDA-9830 Head Unit
2-JLW12 Subs
Infinity Surrounds
Too Many Extras
04' Yamaha YZF R6 Super Sport~
Liquid Silver with Black Ghost flames
K&N Filter, Fender Delete Kit
Aftermarket Mirror Shield
Devil Carbon Fiber High Mount Pipe
Power Commander III
02' Subaru WRX Turbo Sport Wagon
Eibach Springs, Short Throw Shifter
17" Versus Campionato Wheels Wrapped in Pirrelli tires
Old 03-16-2005, 01:47 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Even without a clutch, it is still possible to "power shift" from gear to gear... It's not pretty (or so I've been told) but it can work. You can also clutchless upshift, but that's a little different than what it seems you are saying.
Basically, we need a few more details to help you out better!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 03-16-2005, 01:59 PM
NO, NO, NO
The bike that I have is salvage and it's missing the Clutch and it also is unable to turn on do to some missing parts.
But my point is should the F4I be able to go into first gear with the Kick stand up and NO Clutch and the motor not running.
Old 03-16-2005, 02:25 PM
Z_Fanatic's Avatar
Z_Fanatic Z_Fanatic is offline
YES, it should be, you can play around with the gearbox all you want, the bike will shift, some bikes do it even without a clutch or moving the bike. When you shift to gear and bike hesitates to roll forward and then switch it back to neutral, where it can roll all day long, you'd know that bike IS shifting through gears. IT IS NORMAL.
I'm the greatest!
Old 03-16-2005, 05:39 PM
speediva's Avatar
In that case, Z is right on the money. You SHOULD be able to put it into 1st under those circumstances.
I kinda figured I was getting into stuff you didn't mean, but without more details, I wasn't sure.
Inform yourself:
AF User Guidelines
Old 03-16-2005, 06:20 PM
Your firs replay was correct everyone ell is talking about if the Bike was able to turn on BUT IT IS NOT ABLE TO TURN ON BECAUSE IT'S MISSING PARTS.
saturntangerine I think you are on the same page with me. Your first replay hit the money.
Old 03-16-2005, 06:29 PM
Re: Re: Re: F4i Question ?????????
Sorry about this I Must be the one here.
I Ment ( NaKeDZX ) Is on the Money.
Sorry.
Old 03-21-2005, 08:48 PM
Wheeliest's Avatar
Wheeliest Wheeliest is offline
Send a message via AIM to Wheeliest Send a message via Yahoo to Wheeliest
is this a joke?
Old 03-22-2005, 12:57 PM
aussieidiot's Avatar
aussieidiot aussieidiot is offline
Gone crazy! Back soon
saso,
you have confused everyone with your post. you need to spell correctly and give a full description of your problem. you also need to use more correct terms. not everyone speaks the same as you or understands your terms.
"Has no front end at all. Last night I put the Bike in first gear with out a clutch and not on"
this could have been described a whole lot better and eliminated all confusion.
try
"my bike is a salvage and is missing the front forks, fairings and headstock. last night i managed to put the bike in first gear without using the clutch while the motor was not running. is this normal?"
ok its twice as long but saves time further explaining later.
as a newbie we cut you some slack but please be more accurate and then you will gain more respect and not be assumed a "joke"
