Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-14-2005, 06:16 PM
carli carli is offline
Question Ford explorer 2001 sport trac
Hello - I am new to the forum. I have a 2001 ford explorer with 70K miles. The temperature gauge is note working - though I get heat in the vehicle. Neither does the odometer or the tripometer work - (speedometer works OK). Is this something that can be easily fixed. Just had the fuel pump replaced recently. Please help.
Old 03-14-2005, 07:47 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If the speedometer works OK, and the odometer does not, you need the speedometer assembly sent out for repair. As for the temperature gauge, check to be sure the wire is connected to the sending unit. If it is connected, put a jumper wire across the wires and see if gauge moves to hot. If gauge moves to hot, replace sending unit. If gauge does not move, check wiring for breaks. If no breaks, replace gauge assembly.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-15-2005, 04:06 PM
Thumbs up Re: Ford explorer 2001 sport trac
Thanks for answering my post. I'll let you know how it goes.
