Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-11-2005, 03:59 PM
Christophe Salvain Christophe Salvain is offline
Traction active ...
Hi
The "traction active" message comes sometime especially when I accelerate after when i'm stopped and with the wheel turns on the left or right... Nothing is slipping : the road is dry and I accelerate slowly ...
Trans level fluid is OK.
What's going on ?
Thank you ...
Christophe SALVAING
Old 03-11-2005, 04:16 PM
gls02 gls02 is offline
Traction
Check your brake fluid level.
Old 03-12-2005, 02:25 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Traction active ...
I have been having this problem too. It is prevalent when I accelerate, especially when going up an incline. It also occurs frequently when my cruise control is on. This link might be able to help you---> http://www.automotiveforums.com/vbul...d.php?t=360040
It might be the speed sensor. I'm going to check and spray mine when the weather gets better here in NY and it stops snowing( Maybe April or May LOL).
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-23-2005, 10:27 AM
Re: Re: Traction active ...
Hi all
A little feeback of this problem.
I have unplugged both L&R speed sensor wiring.
One was out of the bracket.
I sprayed WD40 on connector (beware of brake pads & disk !)
Power steering and brake level was low and I added oil and fluid respectively ...
The message has gone and it seems it's fixed.
Thank you for your advices ...
Christophe SALVAING
