Old 03-05-2005, 03:09 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
tach lead wire voltage
yep, another question from me regarding this tach, i still cannot get this tach to work, what i did now is borrowed a voltmeter and tested the volts coming out of the green wire on my tach adaptor, the wire im supposed to hook the tach up to for the signal, while idleing it read .54 volts, i accelerated a little bit and it went up to 1 volt, so im basically asking if this is right? im trying to determine weather the tach, or the adaptor is bad, if the volts i have listed sound right, that will tell me the tach is bad, any ideas will be greatly appreciated, if you need any more info from me please let me know, thanks guys
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-05-2005, 11:58 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: tach lead wire voltage
http://www.automotiveforums.com/vbul...d.php?t=375752
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-06-2005, 12:23 AM
cool, that doesnt help with my question about the volts though, basically i guess what i need is someone to take a voltmeter to their tach lead from the engine wihle the engines idleing and tell me if its in the vicinity of .54 volts, like mine was when i was idleing, if this happens i will KNOW that my tach adaptor is not the problem
Old 03-06-2005, 12:27 AM
Lifted GMT-360!
i forgot what your setup is... what brand tach and are you using an adaptor?
Old 03-06-2005, 07:54 AM
smokey041369 smokey041369 is offline
check the tach and see if there is a switch for 4, 6, or 8
if so make sure that switch is on the number for the engine
4 = 4cyl
6 = 6cyl
8 = 8cyl
the voltage will change because of power demand on the motor i.e rpm's revolution per minute
Old 03-06-2005, 08:18 AM
im using a sunpro tach adaptor, a timex tach (not the most expensive thing in the world), and yes, it is set on 4 cylinders, i have checked EVERYTHING at least twice, everything is the way its supposed to be
Old 03-06-2005, 05:22 PM
anyone else???? any thoughts on the tach lead voltage?
Old 03-06-2005, 09:54 PM
Lifted GMT-360!
Probably the tach. If your getting a signal from the adaptor and the tach isn't reading it, then obviously its the tach.
Old 03-07-2005, 04:02 PM
thats what i thought, ive already scheduled an exchange from the person i bought it from so hopefully the new one is good
Old 03-10-2005, 04:20 PM
turns out it WAS the tach, i went ahead and bought another tach and installed it and it worked fine, now when i get my old one back ill test it and sell it on ebay,
