Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 03-06-2005, 12:48 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
How to: Aftermarket tach install with adaptor.
Well i just spend the last 30-40 min diggin through old posts on this topic for my own sake, and thought since there has been alot of questioning about it, here is a brief write up.
Originally Posted by IXI187IXI
well you have the same engine is me and i did it on mine. Took me about 15 mins to do. On your engine on the right side of the coil pack there is 2 harness's. A 2 pin and a 6 pin. You have to cut the pink wire on the 2 pin harness and hook up each red wire from the adaptor. Then ground the adaptor and run the other wire to the tach. After that just run your power and ground for the tach and thats it. You'll need a tach adaptor and make sure to get the autometer one. If you need more help check out my car domain page, i have pics of it on there because so many people have asked how to do it. Check it out of you need help .
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-07-2005, 01:04 AM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Re: How to: Aftermarket tach install with adaptor.
Stuck
MAKE ART, NOT WAR
Old 03-07-2005, 11:57 AM
Lifted GMT-360!
Awsome! I should post up the instructions that autometer has on their page.
Old 03-07-2005, 02:00 PM
KustmAce's Avatar
Link it.
MAKE ART, NOT WAR
Old 05-15-2005, 07:23 AM
caviman69 caviman69 is offline
Re: HOW TO: Aftermarket tach install with adaptor.
wow im glad i read this. You know how long ive been running a tach tha only reads half. Thanks
Old 10-02-2005, 11:01 PM
Kris_kayton_666's Avatar
Kris_kayton_666 Kris_kayton_666 is offline
Tach Install in a 99 cavalier (with out factory)
is it possible to install the tach in a cavalier that did not come with a factory one, if so is it possible to put it in with out the adaptor
Old 10-02-2005, 11:26 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Tach Install in a 99 cavalier (with out factory)
yes and yes, however you will need a tach you can set at 2 cylinders, since you will only get half the reading, and you need to splice into 1 wire thats connected to your PCM (computer), with a fair amount of research im sure you can find out which wire it is, but its way easier just to get the tach adaptor (easier, not cheaper)
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-03-2005, 12:46 PM
Re: Re: Tach Install in a 99 cavalier (with out factory)
Thanks, do you know off hand how much i would be lookin at for a tach adaptor
Old 10-18-2005, 09:01 PM
Lifted GMT-360!
^^ They range from $15 up to my $79 one from autometer.
Old 10-19-2005, 06:40 PM
Re: Re: HOW TO: Aftermarket tach install with adaptor.
Thanks, also do u know where i could pick one up in manitoba canada.
Old 02-01-2006, 02:01 PM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
its not hard to do it without a tach adapter. when you order the tach just ask if it comes with instructions for a cavalier...it will tell u what wire to splice and exactly how to do it...i did in in like 20 minutes...im not sure if it runs at only half but i think it does....o well
ThE neW wHiP:
Old 02-16-2006, 09:45 PM
97cavy 97cavy is offline
On your PCM locate wire 10 (in your manual it should connect to the TP Sensor). Connect it there. (FYI PCM is NOT under the air filter, rather in the right side wheel well behind the evaporative canister)
Old 07-30-2006, 11:53 PM
Young Chuck D's Avatar
Young Chuck D Young Chuck D is offline
Send a message via AIM to Young Chuck D
this the same in a 2nd gen?
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles]
Gone but not forgotten:
1995 Pontiac Grand Prix GTP[sold, 128k miles]
1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles]
1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles]
1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems]
1990 Hyundai Excel GL [died, 220k miles, died]
Old 04-27-2007, 03:34 PM
taco85 taco85 is offline
good question, is an adapter needed for a second gen with the 2.2 tbi? i'm getting a tach sent to me for my car, and i wanna know before i start installing it
Who you have work on your car is the difference between "Sweet ride!" and "Parts for sale!". Pick your mechanic carefully.
Old 04-27-2007, 07:32 PM
Lifted GMT-360!
Unless it has a setting for 2 cylinders, yes.
