Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-23-2002, 05:41 PM
-Joel- -Joel- is offline
Smile 0-100 & 1/4 Times for a Stock 200SX
I was wondering if you fellow Nissan heads could help me out.
Last night I had a run with a dead stock Aussy 200sx Manual.
It was a rolling start where he droped it back to second at around 50kms and I also did the same.
It started with my front door level with his exhaust then by the time I hit third the nose of his car was level with my front door. Hit third and pulled in front by umm maybe 1/2 a car length not sure but he wasn't near the car.
I've only got a 3" Full Exhaust on my R32 running stock boost only with a little bit of timing.
Without the exhaust I was getting 125rwkw on a DD Dyno @ RPM Performance Center In Adelaide.
To give me an idea what sort of 0-100 & 1/4 times do these Aussy Stock 200sx's pull.
I know that with an exhaust on the 200sx he would whip my arse.
Especially the way they hook up off the line.
Thanx ppls.
Get Used To It!
:monkeypis V8
Old 03-23-2002, 07:57 PM
MaFi0s0 MaFi0s0 is offline
same as ur car stock, 14.6 o_0
these arnt official times though
Old 11-22-2003, 04:06 PM
multilink multilink is offline
Depending on which magazine you read. But Wheels has seen 6.9 0-100km with a flat 15 for the quarter. Motor has posted a 6.3 0-100km and a 14.4 for the quarter. wheels tested on a hot day, so in between could be the go. But my stocker has hosed off a friends 255KW clubsport(buy a hairs length). So I would say under 6.5, but above 6. NOTE: all test so far the s15 is slower than the s14. This is mainly due to the low gearing of the s15 with the 147kw engine. With the 184kw engine, that is a different matter altogether.
Multilink Man
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
