Old 03-02-2005, 01:00 AM
hks_kansei's Avatar
hks_kansei hks_kansei is offline
Question is primer that important?
OK, today i had a look in the local shop to see what paints i have to choose from.
i'll most likely use Tamiya paint in the spraycan, i saw the colour i was looking for (orange) but then i looked and noticed, there was no primer available, of any kind.
no white, no grey, nothing.
so now i must ask the pro's, do i really need primer?
the part is black plastic (fujimi)
i intended to paint it with a two tone job (grey or black bottom, orange top)
the only other alternative is to use Duplicolour (the same colour, but primer is avialable), but i'd prefer steer clear of that, as i dont want to risk melting the plastic, and it is more expensive than the Tamiya paint.
my current project: Nissan S-13 Silvia
Old 03-02-2005, 01:18 AM
kicth's Avatar
kicth kicth is offline
Bear with me, I am not a pro, but I do know that primer is really important and it is a must as I have learnt the lesson.
When I built my very first car 3 months ago as a 100% beginner, without doing any research on car modelling, I have painted my acura without any primer. It was cool and nice when it was done, although I still got some fisheyes at a couple spot, but I was managed to fixed that. However, the paint started to "disappeared" after a few days and I can see the white body underneath it. End up, I have stripped the paint and restart all over again.
The paint doesnt stick to the body without primer. Plus, without primer, the color that you painted will not be the real color as you expected it to be. For example, if you painted a black body with Metallic blue, without primer, the Metallic Blue will look kinda dull.
The only time that you dont need primer that I can think of is when you use white on white.
Hope it helps.
Pro, pls correct me if I am wrong.
Old 03-02-2005, 01:20 AM
sjelic's Avatar
sjelic sjelic is offline
Re: is primer that important?
Orange on black must have primer underneath but like many times before this was explained, primer is not only for better look of colour but also to prevent the paint from pealing of the body once it is cured (so like I wrote before in one thread primer is there to give the paint something to hang on). So take any kind of acrylic primer for Tamiya acrylic (just don't take that dupli colour transparent) if it is gray primer you should put a coat of white paint before orange to have a nice looking orange.
There is a catch of course Tamiya paints on Tamiya bodies work well even without primer but if the body is molded in dark colour and you want to apply the light colour you will still need a primer.
But this is all in FAQ and I will get flamed because writeing it down again
Sasa Jelic
SCALEMAKERS
Old 03-02-2005, 01:23 AM
hks_kansei's Avatar
ok, so i'll have to go searching around for primer. thanks.
Old 03-02-2005, 01:29 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
In short.....yes, primer is that important.
nightmaR3Z
Old 03-02-2005, 03:09 AM
cj_baller13's Avatar
cj_baller13 cj_baller13 is offline
Send a message via AIM to cj_baller13 Send a message via Yahoo to cj_baller13
to find out how primer is important i got a scrap model, primed half of it and then not the other, i layed down the paint job on it and it really does look better with the primer
Christmas Project- Beetle Cabriolet Diorama
"seven straight summers, critics might not admit it, noboddy in rap did it, quite like i did it. if u did it i dont it before you, if got it i had it got mad at it and not want it no more..." Jay-Z the gift and the curse
Old 03-02-2005, 04:12 AM
hks_kansei's Avatar
ok, i need primer.
how about clear coating?
(as you can probably tell, i have never painted a model before, without a brush)
i'm trying to do this on a budget as i dont relly have much to spend.
if i did as i originally planned it would be:
$35 kit + $8 primer + $8 paint + $8 clear + $20 rims + $5 glue = $84 model
that's too much for me, so i'll probably have:
$35 kit + $8 primer + $8 paint + $5 (scratch built rims) + $0 whatever glue i've got left from my last model = $56 model
BTW: does PVC pipe (like they use for sewerage pipe) melt easily?
Old 03-02-2005, 04:32 AM
i dunno bout the pipe lol. but i say clear coating is a must if you want a shiny finish
Old 03-02-2005, 04:44 AM
hks_kansei's Avatar
ok, i asked about the pipe because i was going to use that to make the rims.
make a mould/mold, melt the pipe, and fill mold/mould
mainly because
1: it's cheap and
2: i've got scraps of it everywhere anyway
Old 03-02-2005, 05:00 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
I say don't rush it. If you ain't got enough money just now then wait until you have. If you take the cheap 'n easy options you run the risk of creating a cheap looking machine.
Plus, the spray can of primer & clearcoat will do for many models - not just the one you intend working on at the moment. It may seem a lot to begin with but it's worth it when your results start looking better.
Old 03-02-2005, 05:10 AM
do you have any pictures on your scratch building rims, i for one would like to see it
Old 03-02-2005, 05:15 AM
Re: Re: is primer that important?
Who are you directing that question to? If it's me then, no, I can't let you see them. Why? Cos, I've never scratchbuilt rims!
Old 03-02-2005, 06:44 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Primer yes. To keep it short, cheap and rushed will look just that.
-Mike
Old 03-02-2005, 07:21 AM
Lurchio's Avatar
Lurchio Lurchio is offline
Don't need clear coat for a shiny finish - just good application and some polishing!
Old 03-02-2005, 08:10 AM
tardster tardster is offline
I would like to see how you scratch build rims with pipe aswell, so some pics would be nice.
