Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-22-2002, 03:36 PM
dome's Avatar
dome dome is offline
edjubicate the ignint pleeze
A GSR rear sway bar and front strut tower brace is a direct bolt-on to a 99 Civic DX right?
If not how hard would the mod be? Also the GSR sway bar is something like 19mm right? Will I need a lower tie bar with that if I put it on my civic?
Chunks for the edjubication frends
Old 03-22-2002, 04:28 PM
92AccordCoupe's Avatar
92AccordCoupe 92AccordCoupe is offline
Send a message via ICQ to 92AccordCoupe Send a message via AIM to 92AccordCoupe Send a message via Yahoo to 92AccordCoupe
if there are mods needed, it'd be quite a task to bend and/or cut a 19mm thick piece of hardened steel.
"We spent a lot of time talking about Africa, as we should. Africa is a nation that suffers from incredible disease." -- George W. Bush :right:
Old 03-22-2002, 06:38 PM
dome's Avatar
That's true my man, but I'm not talking about cutting the bar, that would defeat the whole purpose. I'm talking about possible modifications to the mounting point(s) on the car.
Anyone?
Old 03-23-2002, 09:35 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
These are defineatley different bars, your problem lies in the control arm design and the sub frame design, you could swap out your control arms, and fit it, by maybe making a custom plat to fit it up on the subframe. But I think that is a lot of work.
M.Sanew - AutomotiveArticles.com
Old 03-23-2002, 05:30 PM
dome's Avatar
Dezoris, is this something you are sure about? 1995HondaCivic said the opposite on another forum.
I am very confused and am not sure if I should buy the part because if they won't fit there really is no point.
The strut bar will fit though regardless right?
Somebody help!
How to remove the air tube to clean throttle body? hhuytho Regal 8 02-25-2011 03:52 PM
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
Rear Speakers pleez HELP!! Concorde OwNz Jo0! Concorde 7 09-24-2004 10:14 PM
Need Help Real Quick Pleez! HoNdaGrl03 Exterior | bodykits | Lighting 9 07-20-2002 07:53 PM
