Old 03-22-2002, 04:01 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
ECC vs. Non-ECC RAM
This is for DDR RAM:
Actually, all I know is that ECC is more expensive, and that "Error Correcting" is part of the acronym. But how much better is it? Will non-ECC ram work if the MOBO is designed for ECC RAM?
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 03-22-2002, 06:30 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
ECC ram does exactly that: ERRor Corecting. It is used on servers to make sure the data is not corupted. But it will be slower than normal ram. plus more expensive. and motherboards are not specially designed for use with only ecc ram. they might recomended if you use some sever with very important data.
so for a normal computer use normal ddr ram
Old 03-22-2002, 09:01 PM
Chris's Avatar
Oldie
Thanks! Much appreciated
Water VS Antifreeze & Clutch fan VS Non-Clutch PeteA216 Caprice 14 06-01-2007 01:14 AM
Overdrive VS non overdrive automatic trans bissett Econoline 3 03-12-2004 11:08 AM
Supercharged vs. non supercharged mikegee Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 11-12-2003 05:23 PM
moulded Vs. Non Molded Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 22 04-11-2003 10:22 PM
2002 330i: Stick vs. Auto and Sport vs. Non-Sport JonS 3 Series 2 04-14-2002 03:41 PM
