Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-28-2005, 06:34 PM
TheGodfather324's Avatar
TheGodfather324 TheGodfather324 is offline
explosions
I've read that some Crown Vics explode when they get rear ended. Has anybody heard this and if so do you have any info about it?
Thanks
Old 02-28-2005, 10:15 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
yea ive heard of it but look at it this way wold cop be driveing a bomb? i mean ud think its a hokes if the cops still drive them as patrol cars
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 03-01-2005, 01:22 AM
0311_lifer 0311_lifer is offline
please any one correct me if im wrong here but this is what ive heard about the exploding cop cars. from what i understand they said that ford crown vics (03 and younger ?) when hit in the rear will push the gas tank into the rear end and the gas tank will explode. after this problem was discovered i think they put shields or something for police crown vics and basically made it available to any one else who wants it. from what ive heard and please correct me if im wrong but the crown vic has to get hit at around 70mph to rupture the fuel tank and cause an explosion. somehow i think they fixed the problem in either 03 or 04+ crown vics.
Old 03-01-2005, 08:06 AM
im not to familur with this but i guess it makes scence
Old 03-01-2005, 12:35 PM
ModMech's Avatar
ModMech ModMech is offline
Re: explosions
Actually, this would happen to MOST EVERY vehicle on the highway, if rearended from 70+ MPH while stopped. Think about it, what is the most common vehicle to be stopped on the side of a highway? A police/highway patrol car. Therefore they are the MOST LIKELY to be rear ended.
It is true that IF the fuel tank were not rear of the axle as it is, the risk would be lessened, but you can never eliminate all risk. Moving the fuel tank would seriously impact other things the departments want desperately, large trunks, large rear seating, and rear wheel drive.
Another thing to note, if you look at retired police cars and similar, you will find in MOST CASES the department drilled holes in the front edge of the trunk to mount "safety equipment" or radio stuff, OFTEN (yes OFTEN) the drill INTO THE FUEL TANK, then run a screw into it. It is so common, that Ford has issued numerous advisories about where NOT to drill/screw into the trunk. Sadly, MANY upfitters ignore these warnings, and screws puncturing the fuel tanks is a really big problem.
Old 03-01-2005, 05:01 PM
yes your right it was when the cars are stationary. what were those things they started equipping them with i remember hearing about some kind of shield or something between the tank and the rear axle in the news.
Old 03-02-2005, 09:34 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: explosions
Thanks
Go to this site http://www.cvpi.com/default.htm It has links to all the information you are requesting.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-02-2005, 06:06 PM
Thanks guys
Old 03-03-2005, 07:48 PM
bobcoop06 bobcoop06 is offline
Send a message via AIM to bobcoop06 Send a message via MSN to bobcoop06 Send a message via Yahoo to bobcoop06
Re: Re: explosions
Could this be responsible for fuel pump failure??? I've got a '98 P71, and it's on its third fuel pump. (I've only burnt up one) My Dad tried to tell me that it's because I let the tank go under a 1/4 tank
Old 03-03-2005, 07:49 PM
Re: Re: explosions
Could this be responsible for fuel pump failure??? I've got a '98 P71, and it's on its third fuel pump. (I've only burnt up one) My Dad tried to tell me that it's because I let the tank go under a 1/4 tank. (rolls eyes)
You would think that with a hole in the fuel tank, the lack of pressure would screw over the fuel pump, wouldn't it???
