Old 03-22-2002, 02:06 AM
Badass92AccordEx Badass92AccordEx is offline
Send a message via AIM to Badass92AccordEx
Removing front rotors on 92 accord ex
I got some powerslot rotors and was wondering how difficult they are to install. Please respond asap! Thanks!
Old 03-22-2002, 07:51 PM
ShockJon ShockJon is offline
About 2 to 3 hrs and several bloody knuckels!!!!
Its not too bad if you have the right tools and a good place to do it in... A lift is the way too go if you have access to one.... get the tear down book so you can see what tools you will need.... i done mine myself it wasn't too terrible.... Be patient!!! hehehe
Old 03-23-2002, 11:35 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
it is fairly easy. you need to remove the steering knuckle from the ball joint's, and unscrew the drive shaft. other than that nothing really hard, except i couldn't take out the wheel hub. Make sure you have an impact wrench handy. you need at least something that's 250 ft-lbs of torque.
SockJon how did your hubs came out ? Did u need a press to take them out of the steering knuckle ?
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 03-24-2002, 01:35 AM
I had a small pulley puller.... for the steering knuckle..... That was the hard part... I have heard of people taking a pry bar and popping it off that way but I think you could break something that way!!! its not too bad like I said all you need are the right tools and patience!!!
Removing front rotors aluminumpork Accord/TSX/Accord Hybrid 7 12-26-2004 10:14 PM
removing front rotor from 1996 accord hroc2 Accord/TSX/Accord Hybrid 14 07-16-2004 12:55 PM
Removing Front Rotor 1999 K2500 Suburban Ace Greenberg Yukon 0 04-19-2004 12:03 AM
Removing front rotors.....HELP!!! scoop05 Integra 3 08-19-2003 02:51 PM
how to remove front rotor dumpedhatch Accord/TSX/Accord Hybrid 1 12-19-2002 02:30 PM
