Old 04-10-2004, 12:25 AM
aluminumpork aluminumpork is offline
Removing front rotors
Well, I was in the process of changing both my drive axles (damn CV boots) and figured that while I was in the process to do my brakes as well. So I got the rotors and everything was fine until I tried to get the hub (is that what it is?) off. I got the axle nut off, the caliper, everything. The rotor just floats there between the back and the hub. The hub doesn't budge, all bolts are removed. I've hammered the rotor a little to try and bust the hub free, but no success. Can it only be removed by a special tool?
Need help fast.
Old 04-10-2004, 10:08 AM
deaz's Avatar
deaz deaz is offline
Send a message via AIM to deaz
Re: Removing front rotors
Are you talking about that little plate? Take a punch and put it along the side and gently nudge it out with a hammer.
Old 04-10-2004, 01:49 PM
Gold'n Gold'n is offline
Are they two peice rotors? What kind of car is it? What year?
Old 04-10-2004, 03:40 PM
oops, sorry for not posting the year and make. It's a 96 Honda Accord LX 5spd, no ABS and the 2.2 4cyl.
Doesn't seem like it's a two piece rotor. But I was reading somewhere else and found out the hubs are pressed in.
Old 04-10-2004, 03:59 PM
Dave1979 Dave1979 is offline
the 96 honda accord is a tricky car for most. however experience works wonders. have u ever had problems with your starter. if so email me [email protected]
Old 12-24-2004, 12:07 AM
d4h8a1's Avatar
d4h8a1 d4h8a1 is offline
Send a message via Yahoo to d4h8a1
I have the same problem, have you figured any way to get them off without a press ?
Old 12-24-2004, 02:40 PM
AccordCodger AccordCodger is offline
There are a bunch of (detailed) threads on this. Try a search.
Old 12-26-2004, 11:14 PM
WhyteAccord WhyteAccord is offline
This worked for me.
http://www.federal-mogul.com/fmecon...nloads/3501.pdf
This doesn't just take the hub off so you wont have to replace it at all.
