Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-22-2002, 12:22 AM
1993HondaCivic 1993HondaCivic is offline
Arrow Dezoris or texas, please help
i'm trying to find out if i'll have any rubbing problems with 16'' slipstreams on my 93 hatchback. this is just one of the things i've used for proof. http://www.miata.net/garage/tirecalc.html first, i KNOW that the 15'' slipstream with 205/50 tire will fit fine, with it lowered. here so, on the tire calculator, i put in 205/50/15 & 205/40/16. now concering wheel/tire diameter, the 15'' turns out smaller on the calculator. as for tire/wheel width, they are both 205 tires. so what im asking is this valid proof that the 16'' will fit fine? thanks much
Old 03-22-2002, 02:24 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Offset.
The 205 usually does not cause troubles, but if your offset is too low you will rub, regardless of 15-16"
If you have a 42-45mm offset either the 15 or 16s will be fine.
M.Sanew - AutomotiveArticles.com
Old 03-22-2002, 09:38 AM
well the offset is +40 for both the 15'' and 16'' and i know the 15'' fit fine with 205, so wouldnt the 16'' fit ok also if the tire is a 205?
fyi. its 15x6.5
16x7
Old 03-22-2002, 10:02 AM
Mod for life
Yeah it will be the same because you are not increasing the overall diameter. even though it is 16" your tire profile and width are still the same, so just make sure your offset is right and you'll be home free.
Old 03-22-2002, 11:18 AM
ok thanks dezoris for your help, keep up the good moderation
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do! Jinisu2 LeSabre 6 05-13-2010 10:53 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Please Help!! Please Read!!! Please Help!! FromZtoSUV MX-6 0 10-10-2008 08:41 AM
You are now entering Texas,please set your watch back 100 years. taranaki Politics, Investments & Current Affairs 10 01-10-2004 02:18 PM
