Go Back   Automotive Forums Car Chat > Subaru > General Discussion
Old 02-26-2005, 05:20 PM
jstrawther jstrawther is offline
can my 87 GL run w/o a computer?
I've always sort of suspected that my car doesn't have a computer, because I can't find it. The repair manual *haines* says it's supposed to be up under the steering column, but I don't see it. Also, there doesn't seem to be an o2 sensor on my catalytic converter, that I can find, and a carb mechanic I talked to said if the carb has an electronic plug on it then it's computer controlled. And it does. But I can't find the computer. Is it possible it would have been removed before I owned the car for some reason? Can the car run without it? Any ideas appreciated.
Old 02-26-2005, 05:22 PM
I should add that the car does run.
Old 02-26-2005, 05:28 PM
freakray freakray is offline
AF Modelrater
Re: can my 87 GL run w/o a computer?
It could run without a computer, but whoever switched it over would have to know what they were doing.
AF User Guidelines
Old 02-27-2005, 10:09 AM
Did subaru put computers in all the cars? Maybe it was made without one?
Old 02-27-2005, 10:40 AM
AF Modelrater
No, they did not.
AF User Guidelines
Old 02-27-2005, 11:00 AM
But it would be up under the steering column if there was one, and it would be fairly easy to find... correct?
Old 04-22-2005, 07:45 AM
bearcat329 bearcat329 is offline
you might try looking behind or above the glove box, alot of car makers locate them there.
hth
Rick, Ore
Old 06-28-2005, 09:39 AM
Calebz Calebz is offline
If it is a carb'd Subaru, with no O2 sensor, there is no computer
87 Subaru TurboWagon
01 Saab 9-5
05 Kia Spectra5
Old 08-25-2005, 10:33 AM
mgbgtspecial mgbgtspecial is offline
the 87's half came carb'd and with no cpu. They are impossible to find correct manuals for because of this. Fair warning also, part of the carb system is vacuumed so if you have problems with it in the future and the subaru mechanics look it you with the "duh..." face when they can't figure it out.. it's probably the nasty vacuum issue rearing it's ugly head.
I don't know about the fuel injected ones made late in the 87' model run but they may have a cpu, I don't know.
Old 10-22-2005, 03:40 PM
Vidar Vidar is offline
Its just the GTi and turbo models witch are fitted with fuel injection that has CPU's
Old 05-01-2006, 07:14 AM
WTH? is a GTi model.
And once again.. If it has a Carb and an O2 sensor, there is a computer
01 Saab 9-5
05 Kia Spectra5
