Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-23-2005, 12:52 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
95 Gsx
Anybody Got Any Ideas How I Can Fix The Dash Lights On My Car. What Happened Was That I Put The Stereo Direct Without Buying The Wiring Kit And I Wanted To Know If Its A Fuse Or What. Help Quick!!!!!
Old 02-23-2005, 04:23 PM
Re: 95 Gsx
I need help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-23-2005, 05:13 PM
SLoe's Avatar
SLoe SLoe is offline
You hooked the stereo direct to what? Need more info. Did you check you're fuses?
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-23-2005, 08:12 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 95 Gsx
maybe a little more information would be usefull
DSM geek
Old 02-24-2005, 07:56 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: 95 Gsx
Did you happen to check the other 2 post you made about this problem??? ONE POST PER QUESTION!!!!
Here, I will provide you with a like in case you can't remember where you posted the others
http://www.automotiveforums.com/vbul...d.php?t=370148
http://www.automotiveforums.com/vbul...d.php?t=370156
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-24-2005, 11:07 AM
Re: 95 Gsx
I connected the stereo directly to the cables from the car without using the wiring kit. It stayed on for a little but after turning on the lights and turning them off it went out. Nobody can help me???
Old 02-24-2005, 12:50 PM
Re: 95 Gsx
Like loeman said......hooked them to what cables?
Random ECU wires, throttle cable, speaker wires?????
Did you pull the cluster and check the bulbs? Maybe you blew all of the bulbs. Does your tach/speedo work? Do the HVAC controls light up? Did you disconnect the battery when you were doing the work? How did you know that you were using the correct wires? Which fuses did you check (under the dash or under the hood)? Did you check for power going to the cluster?
Electrical problems are very hard to diagnose, even worse over the internet with no information.
1997 Spyder GS-T
5-Speed
Old 02-24-2005, 04:09 PM
SLoe's Avatar
Re: Re: 95 Gsx
I asked him that in one of the OTHER threads, on this question.
They are even harder to diagnose when you are asking the same question in three different threads. Pick ONE of them to reply in, and it will be easier to help you.
Old 02-28-2005, 05:50 PM
Re: Re: 95 Gsx
I checked both under the hood and also under the dash. All the fuses are good. I did not disconnect the battery. I connected the stereo that I bought to where it goes, stereo speaker cables to the speakers in car and battery cable from stereo to the battery cable from the car how it all suppose to go.
Old 03-02-2005, 11:17 AM
hey
So is anybody going to help me or what???
Old 03-02-2005, 02:04 PM
Re: hey
Did you check out the other possible causes that loeman and I suggested?
1997 Spyder GS-T
5-Speed
Old 03-02-2005, 07:00 PM
SLoe's Avatar
Re: Re: Re: 95 Gsx
You should always disconnect the battey when you are working on something like that.
Go get a multimeter and see if you have power to your lights. If you don't give us anymore info, I don't know how to help. Unless you want to drive to Arkansas and let me do it for you.
Old 03-04-2005, 01:00 PM
Re: Re: Re: Re: 95 Gsx
I already figured it out I got the lights to work again I had to take all the dash board and where the stereo goes but I got it. Thanks for everything though and for helping.
Old 03-04-2005, 01:15 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
what he means by direct is that he cut off the stock harness plug-in and wired the radio harness right to the car harness. he didn't use any adaptors from the stock to the stereo.
95 Talon TSI AWD
97 Eclipse GST
Old 03-04-2005, 03:59 PM
SLoe's Avatar
Glad to hear it!
