Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-23-2005, 12:55 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Elecrtic Problem
I Need To Know If Its A Fuse Or A Light Bulb Because All My Dash Board Light Went Out After Puting A Aftermarket Stereo Directly Without The Wiring Kit. I Already Put Everything Back How It Was, Bought The Wiring Kit But Lights Still Out. I Need Help Please!!!!
Old 02-23-2005, 01:38 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Elecrtic Problem
Ok, A couple of things before I try to answer your question.
1. Please lay off the caps lock thing, it gives me a headache.
2. Post only 1 time per question. There is no need for you to post in 2 subforums 10 minutes apart.
3. This is not Burger King, it's not "your way right away". Most of the people in here have better things to do than wait for a new post to appear.
Ok, now on to the question.
I would assume that if you just wired up a stereo and now ALL of your dash lights are out that you blew a fuse. Did you check your fuse box? Did all of the lights go out or just one?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-23-2005, 02:22 PM
Re: Re: Elecrtic Problem
The light to the dash board. It was the rpms the boost gauge, temperature, and the speeding for how fast ur going.
Old 02-23-2005, 02:24 PM
Re: Re: Re: Elecrtic Problem
i checked the all the fuses already
Old 02-23-2005, 05:21 PM
SLoe's Avatar
SLoe SLoe is offline
Too many threads for same question. Are you saying that your tach, speedometer, and boost guage no longer work? You blew a fuse, or cut/pulled a wire loose somewhere.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
