Old 03-20-2002, 11:17 AM
fasterbot fasterbot is offline
Question diesel vs. gasoline
hello -
i am hoping that somebody can give me a quick comparison of a diesel engine compared with a gasoline-burning engine.. i've been looking at trucks, and don't really know what the benefits/downfalls of a deisel engine are..
thanks!
Old 03-20-2002, 12:24 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
If I was getting a work truck, I'd almost certainly "go diesel." I can't think of a big advantage to gasoline engines for anything but high-acceleration applications, and even there they don't always win (but usually seem to).
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 03-20-2002, 12:57 PM
DMC12's Avatar
DMC12 DMC12 is offline
DeLorean Guy
A Diesel engine (if built correctly) will last forever, get great gas mileage compared to an equivalent gas engine, and provide more torque. Look at 18 wheelers! Those engines go up to a milllion miles, and tow tons of cargo. Mercedes has the best Diesel engineers. Avoid early American Diesels... they didn't know what they were doing.
The only downfall of a Diesel is (at least in California) finding a gas station with Diesel. I like gas engines because you go anywhere, but with a Diesel, you have to get familiar with what stations offer it.
What trucks are you looking at?
SOLID! crew (circa 2002).
DeLorean moderator.
Old 03-20-2002, 01:17 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Also, diesel engines don't have spark plugs! However, they have very high compression ratios.
Old 03-20-2002, 01:45 PM
DMC12's Avatar
DeLorean Guy
Oh yeah! Good point I forgot that one... no spark plugs!
Also, here in California you don't have to get smog checks... ever!!! This is because Diesels don't produce the invisible gases that gas engines do.
Diesels are pretty cool... they just get bad raps from all the busses and burnt-out ones that people parade around that beltch out black smoke.
DeLorean moderator.
Old 03-20-2002, 02:13 PM
thanks for the info everyone!
i also just found this, incase anyone is interested: http://www.howstuffworks.com/diesel.htm
DMC12- I'm looking at old International Scouts, and have seen a few listed with diesel engines, that's why i was curious..
thanks again
Old 03-20-2002, 02:38 PM
Um, are you saying that's a bad thing?
Old 03-20-2002, 03:22 PM
DMC12's Avatar
DeLorean Guy
I know nothing about Scouts, but International does make some damn fine semi-truck engines. Good luck.
DeLorean moderator.
Old 03-20-2002, 03:41 PM
MBTN's Avatar
No, I am saying that to explain why they don't need spark plugs. The heat from compression is enough to create combustion.
Old 04-10-2002, 06:51 AM
Tines-Ballantines's Avatar
Tines-Ballantines Tines-Ballantines is offline
Diesel vs. Gasoline
Hi everybody,
This is my first post here, so it won't be too long. Just to check out that it works Ok.
Concerning the Diesel / Gasoline comparison, there are lots of differences but it's also important to say that modern diesel car engines have little to do with those from the 80's or enven 90's, and they are not really comparable to truck engines.
Bye!
"La noche me confunde"
Old 04-10-2002, 09:04 AM
oh yeah? What makes them so different from truck diesels?
Old 04-11-2002, 04:08 AM
Well, there are many differences in conception and technology.
For instance, the injection system is much more advanced and complicated. Truck engines are also much bigger for less power ratio.
* A truck engine such as the Ford F-250 / 350 will give you 185 kW for 7,3 litre = 25 kW/litre, and a torque of 881 N.m = 120 N.m/litre
Let's compare that to some diesel cars using different technologies:
Common-Rail technology, Injection pressure = 1350 / 1600 bar:
i) a little car like the Renault Clio 1,5 litre: 59 kW = 39 kW/litre and 185 N.m = 123 N.m/litre
ii) a sedan like the Laguna 1,9 litre: 89 kW = 47 kw/litre and 270 N.m = 142 N.m/litre
Unit injector technology, Injection pressure = 2000 / 2200 bar:
iii) VW Golf Tdi 1,9 litre: 110 kW = 58 kW/litre and 320 N.m = 168 N.m/litre
So you can see the difference in efficiency. They have less vibrations as well and are much less noisy (specially for the Common-Rail). Fuel consuption is very low.
Old 04-11-2002, 08:20 AM
oh... I thought you were talking about real trucks, not pickups.
Common rail injection has just started being used on 6-8L truck engines in the last few years. Unit injection is used almost universally on semi trucks, and is used on some smaller vehicles. It's important to make a distinction between HEUI and mechanical unit injection, HEUI being the high-tech modern equipment (very competitive w/ common rail, if I'm not mistaken).
The biggest reason that truck diesels have a lower specific output is that they've got to last MUCH longer...
Old 04-11-2002, 09:10 AM
enginerd's Avatar
enginerd enginerd is offline
Go with diesel. No tailgaters, cheap fuel, better gas mileage and more torque.
Kittyloaf™ spectrum analysis
Diesel VS. Gasoline bayoudj Car Buying Q&A 7 06-27-2008 07:12 AM
Diesel VS. Gasoline bayoudj C/K 1 03-04-2008 03:58 PM
dieseling a gasoline beef_bourito Engineering/ Technical 7 11-06-2005 09:22 PM
Which gets better gas milage, diesel or gasoline? Ducaire General Discussion 3 10-09-2005 04:40 AM
