Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-20-2002, 10:33 AM
dome's Avatar
dome dome is offline
Hold my control arm please...
I am looking to do the old shim/washer trick on my rear suspension to fix my camber and was looking for the numerous people on this forum that seem to have done it.
1) Will I need a torque wrench to get off the stock bolts, or will a ratchet w/extension and some muscle be enough?
2) How bad is it to not tighten the bolts back to stock requirements? (26 ft/lbs)
3) Can I take off one bolt at a time, loosening the other just enough to get the washers on? Or will I have to remove both at the same time and have someone (or something) hold up the control arm while I work?
Thanks in advance for any help.
Old 03-20-2002, 11:29 PM
Rice-Rocketeer Rice-Rocketeer is offline
Re: Hold my control arm please...
1) Don't be a girl, use some muscle. And a torque wrench is used to measure the torque being placed on the bolt. A breaker bar is used to apply LOTS of torque to a bolt.
2) Just tighten them down nicely so they won't off under heavy load or extended use.
3) use a jack to hold the trailing arm up while you do it one bolt at a time. But you need to loosen both bolts decently or one will be holding the other so tightly that you won't be able to work with it.
Lookin at my gucci, it's about that time...
Old 03-21-2002, 02:24 AM
G_racer's Avatar
G_racer G_racer is offline
Send a message via AIM to G_racer
Yea that's what i was gonna say. Stick a jack under the trailing arm to hold it up. The bolts are easy to get off. C'mon...im a girl and i did it.:finger:
~**RRREEEOOORRR!!!
I smell....sniff....sniff....SKANKS...why don't you girls just pack it up before I leave TREADMARKS on your faces**~
-1994 Acura Integra LS-
*AEM CAI*
*DC Sport Short Shifter*
*Clear Bumper Lenses*
* Hyper White Lights*
*ITR Shift knob*
Old 03-21-2002, 09:16 AM
dome's Avatar
Easy ladies...:finger:
Rice-Rocketeer-aaaah torque wrench...makes sense...thanks
G_Racer-nice ride
Frt Lower Control Arm scotschult Crown Victoria 12 12-17-2010 10:04 AM
Help for Control arm bushings mikev46614 Rendezvous 2 10-01-2010 07:42 PM
Control Arm some help please citydragon Metro 7 06-04-2008 05:27 PM
Control arms . . . ? CONTROL ARMS!!! i_rebel Suspension 3 04-20-2001 02:05 PM
