Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 03-20-2002, 02:27 AM
CraniumDesigns's Avatar
CraniumDesigns CraniumDesigns is offline
Send a message via AIM to CraniumDesigns
Installing a Spoiler
I am getting an OEM SI spoiler shipped in the mail all painted and everything to match my car. Can I install it myself easily by just drilling and screwing? and do I need new trunk springs to hold the extra weight of the spoiler?
Old 03-20-2002, 11:07 AM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
If you are careful with drilling and marking the holes I believe you'd be able to do it yourself ... It's not hard at all you just need to make sure all holes are marked correctly and aligned properly before you drill ... You shouldn't need trunk springs ...
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 03-20-2002, 06:03 PM
Tominos Tominos is offline
you don't need new trunk springs, its just that now when you pop your trunk it won't pop open by itself it'll just sit there and you gotta lift it. but installing it is really easy just make sure you get it even and use a punch and punch in the holes for it.the wing should come with the install kit, its like 2 pieces of plastic that sticks to your wing before you install it and you put it on the wing and place the wing on the trunk and when you lift the wing off to drill the holes, the two plastic strips should stay on the trunk so you have a perfect template to drill the holes.
Old 03-20-2002, 09:05 PM
xivera's Avatar
xivera xivera is offline
If you get a complete kit, you will have the instructions and template to use for drilling holes in the right place. (You will need a template!)
Taking note that you have the same car as I do, you may need to adjust the stock trunk tension bars. (These are what open the trunk... not a "spring")
Anyway, it's pretty easy... Just make sure that it's painted to match your car when you install it.
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 03-20-2002, 09:28 PM
I bought my spolier from www.spoilerdepot.com they paint it for you to match your car's paint code. Very cool and very cheap. $115 + $85 painted + $32 shipping. ($232.00)
Steve Davis
AF Bay Area Crew
WEB DESIGNER!
www.craniumdesigns.com
Old 03-20-2002, 09:35 PM
Protek's Avatar
Protek Protek is offline
Send a message via AIM to Protek
MUAHHHHHHAHAHAHHH!!!!!!!! I bought an OEM spoiler off E-bay for 34 bucks shipped 2 day Priority mail. Painted it myslef. Paint was 12 bucks a can. Used one can. Primer was 3.50 and clear coat was 3.50.
I got my factory color OEM spoiler for 41 bones. Now that is cheap.
Make it idiot-proof and someone will make a better idiot.
Caution: I drive like you do.
ViS Spoilers chevcav01 Non-Performance 0 04-05-2010 08:12 PM
Trying to find the piece that goes under spoiler but above the tail lights DizzyTwinTurbo 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 01-21-2010 11:18 PM
How do you remove the spoiler from the hatch? Sonic Eclipse Exterior and Wheels 3 10-08-2009 10:35 PM
Whats the best way to install side skirts? Sonic Eclipse Exterior and Wheels 8 04-06-2009 10:51 AM
installing aftermarket cd player jwhite85 General Discussions 3 03-30-2009 10:52 AM
