Old 02-16-2005, 02:59 PM
Wa jang chang Wa jang chang is offline
Timing Belt
Just curious why do many cars use the timing belt requiring routine replacement (i.e. every 60 to 70K miles) and costing consumers many dollars? Why not timing chain that last much longer? If timing belt must be used, why then someone make it such that it would last the life of the car?
Old 02-16-2005, 05:35 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Timing Belt
Some do use chains but they are a packaging nightmare. They require oil pressure driven tensioners, delrin pads to take out slack, and overall can be worse than belts. The problem with a chain that is long enough to do an OHC, the tolerances are multiplied 10-fold over a cam-in-block design. As the chain wears and gets slack, the tensioners correct for it, but the delrin tensioners wear away under the friction from the chain, and the rate of wear on the links can lead to shorter life spans than the belts.
The big reason is money. Cadillac has a pretty good chain setup for its OHC engines. Mind you, its a very large, triple roller chain that is almost 5 feet long and has a lifespan approaching 100,000 miles, but its still not perfect. It requires a computer-sensored, servo driven tensioner that is complicated and expensive.
Belts on the other hand are easy. No special tensioners, so-so service life, they dampen valvetrain harmonics, and are light and easy to package.
You're right. Belts are a pain with their service intervals, but there are considerable trade offs that I don't mind. I just solve the problem by sticking with classic American V8s Ironically enough, racers using American V8s often prefer a belt conversion on their classic iron. Of course, the exposed belt on a V8 is much easier to change than on an OHC, but the belt itself has some marked benefits. Suffice it to say that the belt is better in most ways from an engineering standpoint, except service intervals.
Dragging people kicking and screaming into the enlightenment.
Old 02-22-2005, 09:25 AM
Re: Timing Belt
Curtis 73, You educated me pretty good on this subject. Thanks much for your insights, very informative!
Old 02-22-2005, 04:47 PM
Steel's Avatar
Steel Steel is offline
Re: Timing Belt
Even better is direct gear driven... but that's only feasible for cam in block applications.
Old 02-22-2005, 05:42 PM
curtis73's Avatar
Re: Timing Belt
There are some new theories on gear driven cams. They provide incredibly accurate timing and great service life, but some racers are having trouble with the harmonics being transferred to the cam. In extreme cases the cams have developed stress fractures around the nose, and although the spark is more accurate, some have noticed increased wear on the distributor gear negating that accuracy. I think its bunk, but I've only had experience with them on a street engine that doesn't make as many harmonics.
But, oh the sound of a good set of whining gears on a Hemi
